Auto fwd to manual rt4wd
hello all,
pseudo-newbee here... had my fwd wagon for a little while and i've been fixing it up... little things here... little things there...
until i found some 'inspiration'....
i'm getting things ready for this swap... i've searched... and realize there are a few things i need to watch out for...
my fwd auto passenger side, fender mounted engine mount needs to be replaced with a rt4wd manual one
the floor needs to be massaged to accomodate the new shifter, etc..
the pedal assembly needs to be replaced...
i've been actively trying to acquire these parts from some of the good folks here... and i'm getting there... still need the engine mount and rt4wd pedal assembly....
anyone with experience doing this swap?
any inside hints would be greatly appreciated, i am an open book at this point...
i'll be doing the swap once i gather the parts, get the time, etc. but want to get started on the information gathering...
thanks in advance...
oh, here's what my wagon looks like now.... (with winter tires...)
dave
dave
but yeah, bolting the viscous coupler is the one thing i hadn't thought of... i would want to get the mounts for the coupler... but having the 4wd subframe still bolted to the rear end helps.. from reading bam-bam's swap, i thought there was a hole in the firewall on later model wagons that wasn't there on the 88-89's... hopefully...
anyone have a wrecked, easily accessible manual rt4wd?????
viscous mounts and pass. side motor mount needed...
thanks guys!!!!
