Advice: how to make door close smoother
My front passenger door sags, and can't close properly unless you lift up while closing it. I searched around a bit and the little info I found just says to try tightening the 4 14mm bolts going to the door on the hinge.
I had a friend hold it up to take the weight off and loosened and re-tightened all the bolts and there was no change.
I have never taken a door off before, are there bushings of any kind on the hinge that can wear out?
thanks in advance
thanks in advance
cool thanks. new ones look pretty expensive so I think I am just gonna take one off a 4 door.
If i remember right they are the same
The way I figured out my door hinges were bad was that I picked up the door while it was open. You could actually see quite a bit of play. They are pretty easy to replace once you have the fender off :-)
For now, I lowered the striker on the door jam and it closes nicely.
All the ones in the junkyard had some play in them as well.
