Swap or Mod?
Well, this spring I'll have enough saved to either do a swap, or mod the hell outa this D15.
So which should I do?
I'm thinking modding the D15 would be a lot easier, but a swap sounds more fun..
Basically I want enough power to put it to these stupid Mustangs and other stupid ricers.
So, if I were to swap, I would probably go with a big motor, since I'm going to all the trouble anyways.
But if I were to run the D15, what would you guys reccomend putting into it? Would it even be worth it to mod the D15? I'll probably have a few grand to use.
Basically, I want to run under 10 seconds on the 1/8th mile, and be able to roast off some tire if I ever get the urge. (My sister's stock Civic would run a 10.16 on the 1/8) (I think that was the number, it was around 10)
So, any input would be helpful.
Oh yeah, this motor has 120k on it, and a auto tranny. (yeah I know)
    for a ZC, you've got the bump in displacement (1.6), bump in HP (130), and its a lot easier. pretty much a straight drop in. you'll need a few extra goodies, but other than that, its a lot easier than most swaps. that'll be $800 for a complete engine, and give or take around $500 for various things that need replacement or just adding to the engine.
    B16A is a popular one. again, you've got an up in displacement (1.6 too), and a larger bump in HP (160), plus you've got the added enjoyment of the VTEC. both of these engines come DOHC, so either way you're well off. with the B16, you've got to get mounts and the complete engine itself is around $1300. so you're look at least $2000 for other stuff, maybe even $2500 if you want it done right. i've seen kits on eBay that have a spoon ecu and lsd with the package for around $1900 i think, so you pretty much get what you pay for.
    B18 is the infamous LS engine. you've got more HP and again, larger displacement. no VTEC tho, but you could always add on a head from the B16 for more added fun. same thing with the B20. again, larger displacement. but with that bad boy, you've got a torque happy monster. slap on a VTEC head and fun just spills out from every inch of the engine bay. i think with that combo, we've had a wagonists see numbers around 160HP to the wheels.
    i'm probably ranting on about stuff you already know..... :oops: or not. this is usually a big topic for most people who want more power.
    with both engines, you can do small things to it to gain extra HP. intake is a good one, headers and maybe adjustable cams. a chip for the ecu to burn a bit rich or lean. um, a lot of various things can be done to achieve your goal. and by the way, dont mention street-racing or P will get cha, just a heads up. if you do, just keep it to yourself and off the posts.
    my advice, dont bother with that D15. go with a swap. whichever you choose. you've got many options out there.....so figure out what you're budget is and do some research. what you're gonna need, resources, parts place, and some friends who can help out. a lot of times you'll be halfway thru a swap and find out you need a small part that you overlooked. be thorough, very thorough
    anyone else? that was a lot for me :? i usually dont type this much, but its late and i cant sleep. so some of that info might be irrelevant. someone stop me if im wrong, we all make mistakes. unfortunately, i make them a lot
    in order to lay a spanking on any mustangs or modded civics you are going to need some sort of forced induction. nitrous or turbo. I had a B16 CRX with bolt ons and nitrous.... ran a 14.8 without the nitrous spraying. This was yeeeears ago, before fast and furious 1 even came out. Without the nitrous i would hang with a stock 5.0, and kill most imports because most of them are 'all show' and usually ugly at that. With nitrous i rarely ever lost. You wouldn't believe how many cars DON'T run mid 13's. hahahah. Ooooh to be 18 years old again.
    Anyway... i think you need to set a realistic goal for having fun and still having drivability. The wagon is not a great platform car for any kind of modding. I mean, it is... but it isn't. Dumping money into these cars is on the brink of lunacy. I guess that depends if these are just old honda civic station wagons or something more...
    Personally... I would put a vtec head on your block, spice up the cam and do all the bolt ons, intake, header, exhaust, chipped obd1 conversion. And if you aren't happy, throw a DIY turbo on there and boost to 6psi or something. But there goes your fuel and many more potential problems. oh oh and an Si tranny, that will make your biggest difference.
    my .02
    thats true too. doing a swap would be just for fun, not for winning any races. like quarters said, you're gonna need forced induction. the vtec is gonna help regardless, but you're not gonna see major gains in power. the more you add to the engine, the more you lose. you're sacraficing mpg for HP. and in this day and age, gas prices are gonna climb. also, you sacrafice drivability. the more you mod the wagon, the less street its gonna be. you're gonna get tired of driving that monster on the road, wishing for a more streetable car.
    butttt......it's all up to you.
    I would almost think a nicely built (slight mods/no mods) sohc vtec on obd1 would be better on fuel than the crappy obd0. More power, better milage... sounds good to me.
    But if you have made up your mind to spend the few grand all under the hood, i think the b16 is the most FUN motor to drive around. vtec is great. but given the wagon is heavier than the crx i had, maybe the b18 for the torque. Nope, i still say b16, that motor is just plain fun.
    And i will say that if you do put in a b-series you WILL notice that your suspension and brakes are now somewhat not up to snuff.
    *enter stage left, the beginning of your lifelong battle to mod your wagon*
    oh yeah...i forgot about the SOHC vtec......that is a good engine right there.
    Check this link for engine options:
    http://www.hondacivicwagon.com/board/vi ... =3715#3715
    OR
    I'd go with the last choice for these reasons:
    1)Lottsa T :twisted: RQUE (This is reason enough to do it).:twisted: :twisted:
    2)Gas mileage that stays in the 30's. :D
    3)Fantastic future mod options.(Can easily bring your Wgn into the 14 second 1/4(Screw the 10 second 1/8 mile).
    If you stick to stock & DON'T get carried away with all the performance upgrades.You can keep it in the FEW Grand budget(including the Hasport kit).
    For those that didn't click the link:
    SiWagon wrote:
    :D ZC engines are a popular swap,but I wonder how peeps got it pass smog in Calif.
    :D :D '92-'95 Civic Si D16Z6 is another easy swap.
    The above 2 swaps can keep the OEM wgn .tranny.
    :D :D B16A is another popular swap.I don't know much about this swap.I'm sure 1 of the others will tell u more.
    Make sure you budget everything.One gets nickel & dimed quickly especially with upgrades & replacing worn parts.Even a $400 ZC swap can swell up to a $1,000-$2K project.
    :D :D :D This brings up one of 1 of the most interesting swap.A '02 Civic Si or Base RSX 160 hp K20A3 swap.Around $3,000.Probably no worn parts replacement 'cuz it's still fairly new.A lot of the above engines are 10-20 years old.Great 2 litre torque.Nobody wants these engines ;cuz they're swapping in Type S (or R) or 2.4 litre TSX engines.This is the future of Honda engines.
  • so far ive had a swapped all wheel and now a LS swapped 2 wheel and .... well honda just arent fast .... sad but true i would say get a SOHC vtec or just a Si 1.6 and turbo it you can do all that fairly cheap
    an LS or B16 will not make as much power as a single cam with a turbo and they will cost about the same
    so just decide about money versus pay-off
    if i had my way id just run a stock type R drive train run mid 14's get great mileage and never touch it
    but that will cost ya like 5 g's
    so get a SOHC 1.6 vtec or not and turbo it
    you could do that for 1,000-1,500 easy and when it blows up the parts are easy to come by
    that's the dream right there. a stock honda drive train with good power and good mileage.
  • I think if he was worried about gas mileage he wouldn't be throwing down thousands of dollars to spank a few mustangs. :wink:
    That would be the dream though. 300hp and 50mpg. :D
  • well shit my friends 500 horse GSR del sol still got 29 on a road trip
    and the H22 is stock and makes great power and torque
    or a k series hahahahah
    basically if you want stock you gotta go big .... oh well
    i like the type r casue its kinda meant to fit an ef where as the other stuff is just a bastard hybrid
  • When I am on the autobahn my S13 gets pretty good MPG in town it sucks. I get terrible mpg when my foot is stuck in the turbo.
    I know some guys running stand alone management systems that get about 30mpg with high horsepower motors but they have the ability to change settings for different types of driving. I personally don't tune for MPG I just drive my little wagon when I want to get good gas mileage. As we all know though it is hard to leave this little wagons stock so hopefully this winter I will be putting that ZC in there. however I do have a SOHC VTEC I am also comtemplating so I will watch this thread pretty close to see what you all think also.
    a hybrid is a hybrid, nonetheless. whether it be a ZC in an EF or a V6 RWD in an EK
    it all comes down to what he really wants, how much he wants to spend, and how much work he wants into it....
    cheap means a SOHC VTEC with turbo. a step up is a ZC. next is B16A, then B18, then B20/VTEC, then h22/23, then K20, and K24. that pretty much goes up from price and also work involved. with that K-series, a lot of modding working is going to have to be done to the body to allow fit, and also with that H-series too. in my opinion, dropping down 3K for a k-series and another 2-3K for labor that goes into putting in the wagon, isnt worth it at all. but spenidng total 2K for a simple b-series swap is damn worth it. you've got a substantial increase in power/torque, but its not a huge monster. it makes the wagon even more fun to drive. if need be, simple bolt-ons can be done to get the few extra ponies out of the engine. a k-series would get you some "ohhs, and ahhs" but practicality also plays some role in a swap.
  • Forgot to also say that I love the siplicity of the SOHC Engines, and I've heard that if FI is done right, you can boost your MPG.
    If I were to swap in a B16/B18, where could I buy all the parts, and does anyone have a list of what is needed to swap?
    I'd also like to keep my A/C and P/S, is that possible?
    Will the stock tranny bolt on the other engines?
    I'm not new to engines, but I'm new to the whole engine swap stuff.
    you can buy parts on a lot of places online. complete kits are sold on eBay everyday. if you find and/or trust another site, then by all means, use that site. there are a lot of wagonists that did the b16/b18 swap, and they should help you with the list of needed parts.
    A/C and PS are still possible, but you're gonna have to use a different mount from a delsol i believe
    you plan on keeping it auto? why not change to manual?
    duckie8310
    with that K-series, a lot of modding working is going to have to be done to the body to allow fit...and another 2-3K for labor that goes into putting in the wagon
    FALSE:Remove 1 mount & dent in a 9 square inches of the cross member only 4mm deep.Welding the new mount is the other additional cost.There was a earlier posting by a SWAP Shop that did charge a lot of $$$.It was a class A job, but done W/O the Hasport kit.
    If you would like to find out more go read the Hasport installation manual @ their site.
    FALSE:K20a3 engine/tranny goes for around $1500.There's a K20a3 on Ebay for $1,000(Ebay # 23004501611 )now.For $3K u get a Type S engine.
    like i said in my first reply to this post....
    "someone stop me if im wrong, we all make mistakes. unfortunately, i make them a lot"
  • well i think the point being made was a k series is a bastard of a swap and the the other point being made was they arent as bad as they are made up to be
    i guess the easiest way to figure this out is what is your budget and what is your know how .... then you can decide
    lets say you wanna run a 16 flat that is an ok time for most stock street cars my 96 ex coupe with light mods would barely pull that time
    then you have an easy thing to do
    lets say you wanna run a 14.5 thats gonna be faster than alot of stock cars and that will put a hurting on alot of mustangs
    that to is a pretty easy goal your gonna need car produce like 160-190 horse power
    (i know there are about 1,000 factors that influence these things)
    my friend got a mid 14 out of a b16 crx minor mods
    so weight and power and gearing plus the tires are gonna determine these things
    but as i said first a turbo D series is becoming a very good option the B swap craze seems to have worn off a little and people are rediscovering how good these motors are
    200 horse on a stock d series motor is pretty easy to do
    so just get a budget and work from that
    Lets not get ahead of ourselves here.
    What is your budget? Answer this first and then the rest will be a process of elimination.
    Do-able? Yes.
    Easy? No. Sorry.
    :? Kahuna
    [/b]
    SiWagon wrote:
    :? Kahuna [/b]
    Thats not a budget thats an estimate.
    prolly it means in the lines of $3-5K
    i say get a B16 and boost it! :D and convert to a manual while you are at it!
    10's arent that close to grasp off of a d15. I would swap it.
    make sure you replace all of your suspension bushings and get an alignment after you add more power.
  • I would probably have around $2000 to spend. If I'm going to all the trouble to swap, I'll probably go to manual. The hardest part would be installing the clutch pedal. I've yet to figure out how the dash comes apart on these things.
    When I say I want to run under 10 seconds, that is on a 1/8th mile track.
    Also, the Mustangs I am reffering to are V6 Stangs. I know a import will never have the speed/power of a V8 unless it has tons of money into it.
    So from what I've read, the ZC is basically a drop-in swap?
    My sister's Civic had a D17A1 VTEC in it, and the manual said it had 127 HP, and it was pretty peppy. So, if the ZC is an easy swap, why not do the ZC plus bolt-ons along with FI? Would that be around the same price as a B16 swap but pushing more power?
    NOTE: The ricers around my area consist of Civics with huge body kits and wings, with minor bolt ons and fart cannons. Pretty much what you buy at Autozone.
    If I wanted to go super fast I would buy a 69 Camaro, but theres just something about these little Wagons that are so fun to drive.
    Oh yeah, smog doesn't matter. I live in TN and we don't care about the environment. (haha)
    Like I said before, I really don't know the code of all these swaps and such, but I can do it if I am pointed into the right direction.
    To be honest if you saved up a little extra cash you could go B18C... that would be 180+ hp reliably.
  • hmmm
    2,000
    well with what you just said i would think a LS motor would be an easy ordeal you could look over my build and i converted to manual from auto too
    and any of the motors we have discussed would easily take a 20-70 shot of nitrous for the most part
    if you did an LS swap with a b16 transmission (very quick gears) and cams and bolt ons plus a shot of nitrous you would have a seriously fast car for 2,000
    thats my 2 cents
    all you need is mounts
    150-400
    shift linkages or you can shorten integra ones like 3 inches if you think thats something you can tackle
    50-200
    and someone who can convert you wireing to run 4 injectors
    there is a ton of info online about the swap
    then the auto to manual is easy you just gotta patch a hole and get crafty with a peice from a manual car i used a integra shift boot ring and peice with some pop rivets
    then drill two holes and bolt on the rear linkage mount i did that with a hand drill and a friend holding the shifter in place in side the car
    and then you could wait a year or so like me get your self a vtec head rework it and get another 30+ or so horse power from the same LS motor
