oxbeards steering issues (ball joints)
so i noticed some play in my steering and a little bit of knocking noise turing and decelereting. i thought oh... tie rods. so i bought some. which was a pain in the ass, and everything so far i had to order or go to the dealer to get.
anyway. ive changed tie rods on my eg sedan before using channel locks. pretty much no problem. i tried to replace them on the wagon today... could not get the inner tie rods to budge for the life of me.
my sedan had flat sides so if i did have the special tool to remove them i could use it. but on the wagon they are completely round. the moog replacements i bought have 6 sides so you can use a wrench
anyone had this problem? how did you get those bastards off??
one more thing
i was looking to see if the play was actually in the tie rods. it looks like it may be in the steering rack itself. would i need a whole new rack?
both boots for the rack were ripped in half. you do have to have grease in the rack right?
one more thing
can someone post a pic of how theirs looks?
i was wanting to switch to power steering anyway. trying to shift, turn the wheel, and smoke a cig with manual steering is pretty straining lol
and one question wasnt answered. do i need to put grease in the rack?
Yes....lightly coat it.
Not sure if these pics will help, but I just recently swapped out power steering for manual rack, and replaced the rack end bushing and inner/out tie rods so I snapped a few.
Hope those help a little?
from the pics it looks like theres 2 ball joints on the inner tie rod...?
and it looks like you can take a wrench to the farthest inner part of the tie rod?
i didnt see anything hex shaped when i was looking before. just the round part. ill check again
and how about those rack bushings? i have nooo clue where they even go lol
so since you switched to manual you got some power steering stuff for me?
#10 is the rack end bushing...you can only get that from Honda. I'd recommend going through Majestic Honda if you have a few things you need to get to save on shipping. That diagram should also help show you what's where and connect the dots.
The inner tie rod is held onto the rack by a lock washer (you'll want to replace these) that's crimped down on the nut. The third pic shows using a punch to flatten out the lock washer, then you can undo the nut with a wrench. Also helpful...
It's tight in there, and that's why I always just remove the rack to to do inner tie rods, and rack end bushing. I can never finnagle it while on the car, but plenty of people do. Here's some shots to show you where the rack end bushing is...it's in there good and takes some work with a small flat screwdriver and needle noses to work out.
Hope these help man. PM me about the power steering stuff, I still have it and I'm sure we could work something out if you're interested.
yea i think i have a pretty good idea now. although i spent most of the weekend working on things on the house and didnt have time for the car. i had sewage draining into my back yard... ::cringe:: fun
how hard is it to remove the rack? ive never done it before
when installing power steering.... how do i do that? lol
does it need to be bled somehow like brakes or what?
i figure it might be cheaper to pick a rack up at the junk yard than shipping it to me. hopefully ill have time to go to the junkyard this weekend.
i took out the manual steering rack and the old bushing. then tried getting the tie rods off with the rack out of the car... still pissing me off so i decided fugit ill just go pick up power steering shit at the junk yard. got everything for $70. i was putting it on today and realized that the framing where the rack goes has a smaller indention for the manual rack to fit in. fuuuuck...
so i gotta go back to the yard and get that tomorrow. this has been a real pain in the ass. my car has been sitting on jacks for 5 days now. IT SUCKS!!!
so anyone who wants a manual rack its up for sale. new boots and new end bushing included.
ill be putting it in the marketplace soon.
i got the frame for the steering rack. it was a son of a bitch. so much shit to take off at the junk yard, then had to do the same to my car.
i got everything put back together and when putting the rack back into the car i found that one of the holes where the rack is supposed to bolt into DOES NOT HAVE ANY THREADING IN IT!
looks like the nut that was welded inside the frame came loose...
i was worried about a solution until today i decided id just drill all the way through the frame and get a longer bolt and nut and just have it go all the way through the frame.
i drilled the hole then went to home depot for a long ass bolt. when i came outside it was frickin pouring down rain so my car is still out of commission.
the neighbors are bitching my car has been on jacks so long and a guy from the city came by and said i had to fix it in 2 days or ill get a fine... FUCK YOUUUU!!!
im starting to wonder if it was worth it. we'll see when i finally drive it again i suppose
That sucks about your misfortune! Good luck.
Good luck.
steering is smooth as eggs now. only have to use 1 hand to turn the wheels even at slow speeds. which is good because i need one hand to finger my pussy. lol
there is 1 problem though. it feels a little loose. i took it back apart and looks like the slack is in the outer tie rods. seems like the ball joint in it is ok. looks like it the bolt is moving around in the hole. i put it on pretty tight. whats the dealio?
...and yes inner tie rod replacements are complete cumdumpsters. I'd rather swap all four corners of shocks/springs, install camber kits and align the shit rather than dick around with inner tie rods.
while doing so i noticed my ball joints are shit. i cant wait until everything is golden and brand new.
i did some searching and didnt find any how tos on replacing ball joints. so how do i replace those bitches??
doitdub, hook a nigga up with pics
another thing is, while driving i can hear a scraping, grinding noise. im thinking brakes but im not sure what is causing it. while putting the tie rods on i was turning the wheels while off the ground. it feels like the calipers arent letting all the way off. the calipers are brand new. i had this sound going on before right after i replaced the calipers then it went away. but now after doing everything with the steering its back.
how do i fix this?
