KYB AGX Struts
I just put a set of KYB AGX struts on the front of my car. For $166 shipped I can't really complain, they are new, and slightly adjustable. They are only adjustable for rebound dampening, and have 4 settings. Setting one feels about like stock struts, setting two feels about the same but you can tell the car responds better in turns. Setting three feels better than two but about the same in turns. Finally, setting four is about what I would want to start off as a baseline for a good amount of dampening for me. In the instructions it says "don't lower you car more than 1 and 1/4 inches." Mine is lowered about that much, and I'm about to make some extended top hats, so they will probably last for a while. That kind of sucks cause I won't have a good excuse to get real coilovers anytime soon. I need much more adjustability than these will give! I better start saving up for some KW coilovers.
Bottom line: Good as stock replacement, don't fool yourself into thinking they are the bee's knees just because they are adjustable. If you really like to drive your car hard, you will never take it off of setting four. Most good setups are 3 way adjustable for dampening!
http://www.youtube.com/watch?v=B0wtoLuZnc4
^im the guy holding his ears and setting the data logging on the back of the car when its lining up to the tree..
Where did you get your AGX's for 166?
Oh!!! You got them for the fronts only. Heh. I thought you got a set of 4 for 166. :oops:
