89 RT4WD Z6 Swap help!
I have a Z6 in my 89 RT4WD that i'm converting to OBD 1 and the motor cranks over and i have spark, but i'm not getting fuel because im not sure which connectors from the ecu connection are for the injectors(Ex: A1, A2, A3). I was wondering if anyone has a schematic for the ecu connector or has ran into this problem and can give me some info. PLEASE HELP ASAP! Thanks
Here's a diagram from the mpfi swap info I accumulated. I'm pretty sure the injector wiring should be the same for the z6. All that stuff on the left is the injection wiring. That diagram is looking at the ecu plug from its backside, the side the wires go into, not the side that plugs into the ecu.
http://www.rywire.com/store/images/inst ... jumper.gif
