Rear Damper Unit Problem.
ok so the rear lower arm damper mounting bolt is fucking stuck and on there tight like a virgin.
how do i losten it up or take it off with out breaking it, and if i do break it where can i get a replacement?
i cant put my coilovers until i figure this out. :x
Blaster's PB is highly recommended.
If you do damage the bolt, no big deal. It's nothing special-just get another one.
if i break it i just get replacement at a hardware store or anywhere specifically.
im pretty sure a hardware store thats where i got the self locking nuts and the bolts caught my eye but i didnt know the measurements of it (service manual doesnt state either) so if i break it ill just take it and hopefully they have it.
Thanks.
this is like the 3rd honda ive seen this bolt stuck like hell. :x
how 'tuff' the metal is...
also as a reference how much torque U
can or should use...
best of luck with the wrenching.
Pretty much any torch that can get the bolt red hot will do.
what are the chances of the other 2 bolts on the lca breaking off aswell?
the rear sub frame bolt came out easy for me, the outer 2 on both of mine were trash, i went to honda for new ones when i did the poly bushings and struts.
