First gen 4wd Cr-v Driveshaft in wagon?
has anyone considered this? i dont have acess to a first gen Cr-v so i cant measure but if it was the correct length what would stop us from bolting this up (plus the support bearing if it has one) and putting an LSD in the rear end to have true AWD?
guess you didnt catch the part about bolting a D series LSD up in the rear...
and there are no other Rt4wd civ's around me, otherwise i would have already done that
if the length is anywhere close ill make adapters for the flanges
it was my understanding that the LSD replaced the center diff correct? im just asking about the cvr driveshaft because if it is the correct length then i could have acess to one of those waaaay easier than finding an rt4wd driveshaft...
if the Crv driveshaft doesnt have a viscous coupler then whats the difference between running on of those and the custom one piece drive shaft you have (besides weight, this is also assuming LSD in the back)
The LSD that I installed in my rear diff has nothing to do at all with splitting the torque between the front and the rear wheels. It only acts as a go between for the rear wheels, along the same lines as an LSD that would be installed in the front of a FWD vehicle.
I think I understand what you're trying to do. You want an LSD (or torque distributing device) between the front and rear wheels. Something that will lock when there's a speed difference between front and rear, along the same lines as the OEM viscous coupler, but mechanical instead. I know Quaife sold some for the center position on the 1st gen DSM AWD vehicles. Otherwise, I don't think you could fit a regular LSD in the front to rear driveshaft. Either way, it would involve a ton of fabrication, so while you're at it, you may as well manipulate the length of the CRV driveshaft and fit it in there at the same time.
no im trying to do somthing similar to your setup, but instead of using a custom carbon fiber driveshaft i would just use one from a CRV... are you saying that wont work?
and turbo teg, if you wanted a driveshaft you could disengage why dont you try to find the driveshaft ou6\t of an 85-87 wagon with the wth the push button disengaging driveshaft?
i guess im not seeing how there will be more wheel bind than your setup if i put the LSD into the rear diff exactly like yours but use the Crv "solid" driveshaft instead of the custom driveshaft your running?
Im all about the LSD that sounds awsome but i dont recoment a solid driveline for daily driving it would be fun to have a solid driveline for autoX or gettin crazy in the snow.... hope this helps
right but if there was an LSD in the rear end wouldnt that allow the wheels to turn at different speeds? thus performing the exact same function as the viscous coupler but the rear wheels are always driven?
i see... well then wouldnt this mean the whole idea I was going for (that we PM'ed about) wouldnt work at all?
Otherwise, just go with the OEM setup. I understand you're having trouble getting a driveshaft. I guess that's the cross we bear when we're dealing with a 20 year old car with limited production numbers.
I was intending on going AWD with a solid shaft and an LSD in the rear end because i was under the assumption that the LSD in the rear would eliminate that wheel binding issue...
and i REALLY dont see the point in keeping the factory viscous coupler because I hate the way the entire system works, I would rather have a way to disconnect the rear end completely when i want
which means I guess ill be looking for a 85-87 driveshaft with the electronic disengaging mechanisim...
The 84-86 4x4 (not realtime AWD) wagovan do have a pushbutton on the dash to dis-engage the prop shaft.
Vacuum actuated, it disconnects the rear output of the transmission, as if you were manually moving the 'tow' lever on the RT transmission units, that's it.
It's won't directly 'bolt on' as the transmission cases and rear 'T' Bracket are different. With some fabrication, it would be more than possible. There is also a control box mounted on the firewall that houses the solenoid control valves, hoses, etc.
yep, you sir have just provided pic of exactly what i was looking for.... thank you very much
it would be kinda hard to route that... unless it was a wire, i would kind of rather use an actuator... if i already had a driveshaft i would just make this setup, but i do not... so im trying to find an entire setup all together
