Transmission problems maybe?
Hey, looking for some knowledge thats better than mine.
My 1989 Wagon decided to die on me. Here's the sequence of events. I was driving and stopped. when i went to go again i put it into first gear and started to go. About halfway through a left hand turn from this stop sign. There is this popping noise and it gets kicked out of first so i go for second and nothing. I'm not sure what is going on.
A few bits of info that might help. I can now put it into gear without needing the clutch, When it is in gear and i rev the engine, the speedometer moves, which leads me to believe that the gears are engaged. So somehow power isn't getting to the drive shafts.
A couple friends think it might be the diff that is broken. Any sort of help would be awesome.
Let me know if you need any online help opening up that transmission, I've rebuilt 3.
They say, and I have to agree...
and maybe some clutch too...
But that's noticable when you
wrench that thing ...
So let it be and dunno...
What's next?
Order parts/numbers
Junkyardhunt, classifieds...
If you need to take the transmission apart you might as well put in new bearings while you're in there, at least the input shaft bearing (known to go out).
Yah's been my one and only daily for about 4 years now. i'd really hate to see it go, it's been such a great car, i just want to keep it going
and some patience too...
When did you want me to bring the jack, jack stands and tools over?
that's more work area, it's pouring rain right now
i got the axle off with a little bit of work and some time
thats where the axle goes and when i feel the problem begins, you can see that cog that takes up a bit of where the axle goes
Those last three are just some close ups, i could get my finger in there and move that cog around no problem. I don't really know anything about transmissions, but to me i don't think there should be a cog just freely floating in the transmission. So if that is a cog that deals with the differential, then something is busted. But when i drained all the oil i didn't notice any metal chunks coming out.
