Well, the wagon ran out of gas, and I happen to live in the NE. Now my little champ won't start, filled her up and all she does is crank but won't turn over. What can I do?
there is a little bolt on top of your fuel filter, take that off and turn the key to on, and if gas shoots out your fuel pump is working. you should check all your grounds, spark, main relay, yada yada. i hated dropping my gas tank to replace my fuel pump.
Ok so the fuel pump works, found oil in plugs, replaced vc gasket, added seafoam to the fuel, and still will not crank over. It tries and tries but just won't turn over, compression is good. Someone help.
if not, it could be a bad Distributor..
voltage levels ok ?
reference this
http://techauto.awardspace.com/faq.html
