Y8 head to a d16a6 what do i need to make it work
i removed the oil restrictor from the block.
i wanted to make sure i do this right.
so far i have this.
headgasket for civic 2000 ex.
distributor for civic 1992
what other parts do i need to go along with this swap?
so far i have this.
http://www.hondacivicwagon.com/bb/viewtopic.php?f=7&t=1459
He used:
D16Y8 Head
D16Y8 plugs and wires
D16A6 IM/EM
D16A6 Distributor
Summit racing RPM switch to activate Vtak
I added
New headgasket (bought it with a blown headgasket)
ARP headstuds (Lightning motorsports sells a custom set for minime conversions)
im thinking i need a 2000 civic ex parts.
9 z6 head bolts and 1 y8 head bolt (goes in the shorter of the head bolt holes)
96 ex head gasket
96 ex dizzy with both side of the dizzy plug (just depinned my old dizzy plug and repinned the the new plug)
p28 ecu
obd0-obd1 ecu jumper with vtec plugs(http://cgi.ebay.com/ebaymotors/ws/eBayI ... 4118596223) this one
96 ex timing belt
96 ex plug wires
98 hx plugs ngk g power (better for higher compression)
motor ran great and got excellent gas mileage. hope this helps you out sir.
Also, there is no need to put an OBD2 distributor on your OBD2 head. The D16A6 distributor works fine. The only odd-ball distributor is the Z1/Z6.
