87 4wd problems :(
first off i'd like to say hi and thanks in advance. i've had my 4wd wagon for about 4 months now and finally i got to use it in some ice and snow! shitty thing is i don't think the 4wd works. any suggestions on where to start looking for problems? the whole reason i bought it was for the winter time, but if the 4wd isn't working then there's no point in having it.
thanks again for any help
Thats all I can think.
-Brian
-Brian
i guess i'll try cleaning out where the bolt used to be and maybe order one from honda. why do you think the bolt has to be there? the lever has remained in the 'engaged' position since i switched it a couple weeks ago.
IF the bolt is missing then it fell inside the transmission housing
IF this is the case you may be out of luck and that bolt may be dancing around with your transmission internals.
I hope this isn't the case, please follow up with us & let us know what happened
It could also be an electrical short between the button and the coupler. I suspect, as its an electronic swith, the coupler is an electro-magnet. maybe the magnett is bad. but then, that may be part of the coupler itself.
I know my 86 had some wiring short out. just from age. so it could be the same with yours.
86 according to D was the last year whereas the 4wd involved a button.
The only reason I say this is because the 2nd wagon I bought came with a spare 87 rt4wd trans & it had the toggle.
any updates yet?
AFAIK, all '85, '86 are 4x4, ie, straight prop shaft with a solenoid operated vacuum actuator on the transfer case linkage. My electronic parts catalog along with honda parts online show '87 with a viscous coupler, hence..
Can someone snap a pic of the actutor to disengage the transfer case on the 87+? It would be my guess that honda just changed the linkage and the rear T bracket to no longer accept the vacuum actuator, and probably just added a tapped hole/boss for the safety/actuator hold down.
I've been meaning to post pics of the 4x4 setup for some time now.... maybe i'll get off my ass over the holidays and do so.
D
