(d16a6)engine (swap )advice needed
The D15B2 engine in my auto 91 wagon is leaking oil from the crank and main seals. Yes I know, it isn't pretty! I was planning on converting to 5spd and MPFI, but since my engine is high mileage (295,xxxkm) and needs work anyway, how easy is it to swap in D16A6?
I know the A6 will drop right in but what else is required?
These are the parts I am gathering:
-Si engine harness, injector resistor pack & Si ECU
-A6 longblock
-5spd wagon tranny & linkage
-Si pedal assembly
-Si axles
Can I use my auto gauge cluster? I have an auto JDM cluster in my 5spd EG HB which works fine, so I assume my EF auto cluster should work. Anything else I might be missing?
Any help would be greatly appreciated!
TIA
-A6 longblock
-Si pedal assembly
-Si axles
TIA
even if u dont decide to do a d to b swap i still recomend u check out rywire.com they will have the harness to convert your car from dpfi to mpfi and i bet they can help u on the wiring for the auto-5speed conversion as well.
Thanks for recommending rywire. I've checked out their website recently. It's good to see a company provide great service.
