Quarter Panel Replacements
whats up guys
got my first wagon about a week ago and its got tons of rust
so here my question
where do i find new quarters for my wagovan?
do they make them and if not what are my other alternatives?
i know a purdy good body guy thats gonna help me do the work and im now on the hunt for panels
any input is great
thanks
so here my question
any input is great
thanks
i did some hunting but couldnt find any
thanks for the help
i never thought of that...
ragenasian,
what did you do to fix your rust?
and yes, the arch flare is completely different to CRX and Civic 3/4dr
they have some for an 88-91 sedan, but i don't know if they will work.
here's the link to the quarter panel "skin:"
http://www.fixmyrust.com/Product/5130816.html
here's a link to the rear "arch:" (i'm not sure what-is-what)
http://www.fixmyrust.com/Product/5131058.html
(the website is slow to load)
Is it that they fit ok but don't flare out enough to look stock ?
But if you were replacing both sides then you'd be changing the look of the ach, but that's not a great deal is it i it looks like it's supposed to be there ??
I'm getting desperate :?
If you're going to be cutting & welding anyway, you could just flat sheet metal and weld it in piece by piece.
As long as you're careful, you should be able to match the contours of the arch, and fix any issues with filler (not thicker than 1/8" preferably)
show us some pics, also, SEARCH is your friend, there are tonnes of people on here doing the same thing
Some people are using front arches to fix the rear. I forget which side but one of the font fenders is now out of stock at Honda.
Fat chance of finding good condition ones here...
My arches are bad but livable. Only going to get worse. I suppose it's a good time to learn to spray properly. metal work isn't a problem, I can buy some new tools to do it like a pro as well. Matching the contour just needs more tools.
But sedan rear arches are $30 here. Front wings about $50.
If I can get them in then it'll alter the way it looks but by far the easiest way to patch up the rust.
I've seen people on here doing it with fibreglass. No thanks...
Perhaps the one to try is a plastic/rubber arch cover which matches the rest of the trm. I was gutted to see that the Beagle has a painted strip and not an arch cover. That wouldn't be a problem.
I wonder if I were to produce some arch covers if there would be any interest in them??
A nice mod to give the look of flared arches and a damn cheap and easy way of fixing rusty ones.
how about it Bam...
you blacksmith you...
ahaaaah !
choking...
ohwell...
i'd be more interested in the fenders... although shipping to canada could be like riding bareback
Or alternatively, get one and make some replicas = profit $$$
Here is what I'm comparing:
It looks too close to be true ?!?
Tho it looks like the shuttle arch is longer than the sedan. Anyone?
Of course I can just hide it like first thought:
viewtopic.php?f=9&t=2356&hilit=jetta
As much as I want to weld in new metal, I don't know how to weld and can't afford to have someone do it for me. I was thinking of fiberglassing some flares instead.
Just make sure to pull out ALL the rusted metal, or it'll come back
Then smooth, and use a GOOD etch primer / sealer, and a couple coats of high build, sand, and paint.
Paint is important because it'll make a water tight seal over the repair.
This won't last as long as cutting out the rust (probably a year or so depending on how well it's done) and welding in new pieces of metal, but it'll get you past inspection and be quicker and cheaper....
Osoyoos/Oroville is pretty close. Why ship all the way to Kelowna?
