Transmission fluid changing?
Could someone tell me how to change the tranny fluid in these cars? I've done it before, but it was just a simple drain plug out, new filter, more oil type of deal. On this, I don't see a way for the tranny to even have a filter, and I don't even see a drain plug. So if someone could let me know I would be very greatful. Thanks
I'm guessing 2.
facing the Wgn.Look 2 the left of the dip stik.Below the side cover,toward the frt.is the drain plug.I think it's a sqaure drive plug.
:idea: You may want to change over to a Hi-po ATF like "B&M" Trick Shift fluid.
Why would I want to change tranny fluid to that?
It is a 2wd.
Is there no filter on the Honda trannys?
:idea: I highly recommend the 30K oil change (factory spec)& installing a trans cooler(90% of AT failures are from HEAT).Honda AT's need all the help it can get.They're NOT that strong.
:arrow: Oh.1 more thing:Honda AT trans fluid level is checked on level ground with Engine off(w/in 1 minute of engine shut down).
:twisted: DON'T overfill above the upper mark or underfill below the lower mark unless u want the tranny to FAIL :!:
