Question about rotating distributor to change timing.
Ok, so my original distributor died. I swapped it out but unknowingly forgot to mark it's original position, so I would have it right for the install of the new dizzy. I still have a code 9, but I will tackle that problem later (hopefully a different ECU will cure that)
As of right now, the timing seems way retarded. The motor seems to run out of gas at about 3,000 rpm (maybe the code 9 is messing with things?) I just need to know which way to rotate the dizzy to advance the timing a little bit more and get back a little bit more of the midrange. Before the swapout the motor ran great from 2000-3750 rpm's, which is great for daily driving.
I have no timing light and will be doing this by using the seat of my pants trial and error method.
CW = Retard
I'll just have to play with it tomorrow. Thinking back, it may be advanced too much. It sounded like a box of rocks past 3500 rpm.
Could you show me a pic or describe where the jumper is?
Be sure you reset the ECU before you do any of this.
There's an open in the wiring somewhere :evil:
