91 seat automatic belts?
Hey guys my 91 wagon has those gimmicky automatic shoulder belts that slide away when you get in and slide back when you close that door.
are those covered by the recall?
also Im thinking of switching seats with DC2 integra. but what about all that hardware for the seatbelts? if i swap seat pans to keep the stock brackets and what not, will it fit?
is it possible to get normal seat belts and retrofit them in and take out the automatic belts?
http://www.hondacivicwagon.com/board/vi ... .php?t=104
see those big bulges by the seat buckle? and if you look up at the top left corner of the picture there are those auto shoulder belts. can I remove those and use normal seat belts?
is the mounting hole behind the B pillar garnish? like on normal wagons
:arrow: Yes,but depends on the serial#'s.
my auto seatbelt does not retract. I sent it in to honda and they said its not the retractor. it is either the "door latch assembly' or faulty wiring.
I need someone with a helms manual to take pics of the auto seatbelt assembly. or check if there is anything that mentions about the door latch. thansk
