4wd on 3rd gen
Hi, from what I've read here rt-4wd wagons (4th gen) can have close to 50% of power to the rear wheels, but on red pepper racing (3rd gen board) faq they say; "The Honda 4WD only sends 10% of the engine power to the rear wheels"
http://www.redpepperracing.com/wiki/ind ... _my_CRX%3F
Is that true, or the guy is wrong and the 3rd gen is working about the same (close to 50/50 possible) as a 4th gen?
Thank you. Hope I didn't buy "the wrong one".
Someone correct me if I misread the FSM.
The internals of the gearbox are 100% pure mechanical. Gears, plain and simple. The drive to the back wheels is slightly underdriven in relation to the front, so if the fronts slip, once the viscous coupler locks (almost instantaneously) the power goes to the back wheels.
thanks
and rwd, for 2 days before the cv joints are shot
Also, actually when I park (enough cheap winter tires) in slush/snow/ice I feel like the 4wd isn't working that great, but on snow with some speed(like 10kmh, jsut nt stopped) then it looks to work well, nice traction and drift.
it's a common ratio...
and even if it only distributes that amount
of torque...
you will have improvements up to 50%
compared to a 2wd system...
torque engineered to...
re-establish overall traction
100% (or as close as possible to) of the torque travels to the rear wheels if you really get the fronts spinning. Wagon rear axles are beefier than CRV rear axles.
I suggest you read through Jakers RWD thread.
That's weird.. The 3 bolts for the intermediate shaft had come out and my driver's axle came out of the tranny and I had no power to the rear. When I gave it throttle it would just rev up and not move the car at all. Any ideas on why this would happen??
(bolts have been replaced since then)
And do you know if 1987 2wd wagovan front shock absorbers will fit a 4wd bolt on? I plan to get 2wd wagovan kyb gr2 (no more oem honda), will these need some fittement work and do I need the kyb strut mount (like 35$ each)?
thanks.
Now, mind you his driveshaft was welded solid. He had no viscous coupler. So maybe the viscous coupler can't handle all that torque/power (completely open front drive).
sure ab. correct oil and quantity...
no
viewtopic.php?f=16&t=5382
viewtopic.php?f=7&t=4949
one of these...
somewhere...
but i'm angry, I went t buy front cv joints to a rebuild shop and they gave me the wrong ones
I want delate clutch visco it's good indea??
