Skunk 2 coils
Has anyone had an experience with these. Looking to dump my cut coils and upgrade to somthing affordable.
Just wondering how the ride quality was.
Or if there are any other coils that are better in the genral price range that someone can point me to. Would also be great. My wagon is for daily use and is all stock just cut springs so nothing special.
Fyi...the skunk2 coils are thicker than the gc so I am wondering if that is gonna make it ride rough but dunno will see.......
could I run these on my stock shx and not be to high or whatever in the rear.
I was reading one of the threads about what all suspension fits the wagon. And I was getting confused lol it was to much information at one time.
Also planning on getting some new lca's is there a certain year or model specific ? I have a 89 2wd wagon
any pictures of how low skunk 2's will get the wagon?
I'm interested in being 'slammed' and not just 'lowered'
any info would be great
thanks guys
http://jhpusa.com/store/pc/viewPrd.asp? ... oduct=2981
are these worth the price matted with the skunk 2 coils I posted Above ?
Looks like they should work fine together...
Try looking through this
viewtopic.php?f=5&t=4217
Hit "Control F" on your keyboard and type in Skunk in the search box. Should give you some hits on the coils.
This car is a dd that they will be going on so it's not like handling has to be perfect. Id rather have as much comfort as possible while still being low. Which probably contradicts it's self
Do those coilovers on your car bottom out in the back alot when its super low? Because the set up i bought rides like shit in the back.
Towards the bottom of this post you will see my wagon with Skunk2 springs and KYB GR-2's with extended top hats.
http://www.hondacivicwagon.com/bb/viewtopic.php?f=8&t=3664&start=30
Since that pic I cut a few coils in the rear so it is more level.
The ride was great, but the shocks are totally worn out...the right rear is even leaking. So def recommend a "sport shock" as opposed to an OEM if you want to have the shocks last. I'm looking at Koni STR.T, Skunk2 Sports, and Koni Yellows (of course, if I can afford it!)
cheers,
jeremy
Since then, I had it raised a bit for daily duties.
Definitely do not recommend stock shocks. It's almost dangerous when I hit a bump on the highway. The car goes up in the air. Spend the money and get aftermarket shocks with it.
from looking at the pro s coils i thought they were adjustable. so now after reading your post im assuming there not. ud figure for almost about $725 theyed be adjustable.
any thoughts would help.
thanks
