Looking for a lever so I can control transfer case from seat
I converted my RT into part-time by welding up the viscous coupling. I use 2X on the street and 4X offroad. I've been doing this for a couple years but would like to have the ability to do it in-car. Right now I have to get under the hood with a socket and move the lever manually. It's ok but when in the dark and snowing out not much fun.
I was wondering if anyone has made a shift lever / cable setup so you can shift from the driver seat?
I'm running kumho rally tires. Is there anyway to get more traction out of this car other than welding the rear diff? I need to be able to drive street so welding the rear diff is out of the question.
Sorry.
Would be very cool though.
85-86 and possibly early 87 does not have a viscous coupling. The linkage for the 4x4 on the transmission is controlled by a solenoid actuated diaphragm. I have a pushbutton on the dash that operates it.
If you want to convert it to manual... i'd suggest maybe using a cable actuated setup... will probably be easier for routing as opposed to lever/hard linkage. Use 2, one to pull engaged, one to pull disengaged.
