How to: Remove Doors
In order to remove the front doors, you'll need to:
1) Remove fender
2) Open door and remove pin in door check by tapping with a hammer underneath
3) Close door and undo electrical connector
4) Remove 4 bolts at door hinges - the ones going into the door, not the body
5) Lift up slightly and out while opening the door
* Rear doors are the the same but you don't have to worry about the electrical connector
** Install in opposite order and having someone hold the door/line up while you tighten bolts will help make your life easier and safe your back
*** If you have pin stripes, use these to line up the panels
**** Make sure the door is lined up where you want it before you put on the fender
1) Remove fender
not necessarily
comedy hour on HCW...
my favorite sitcom...
... the next show???
when ???
