RT AWD diff shatter(edit) Couldn't part with the Wagon
OK so I just turboed my 89 RT AWD and I shattered the gears in my diff. I removed them but I want to know if I remove the gear to the tranny and put the rear back in if my car will run FWD? or if the weight will me transfered to and my car will not go anywhere,,,, I understand that i will be dragging(pulling) the rear end but before I put it back together I wanna know if it will work. should I take my drive shaft off?? ... I am very new to the honda thing and have dealt with toyotas all my life ... please help.. Ill try and post tom pics
and heres what it looks like
EEEEWWWWWWWWWWWW lol. Sorry bro. I say if you dont have the coint to fix it or get a new trans, you should get it back together and turn the 4wd off (just mt.02). If im remember right, the way to turn the 4wd off on the manual, is some sort of adjustment near the IM. Might have to search it.
I'll try and find the page in my Helms and scan it for you.
You're scaring me though. How were you treating the car? Were you beating on it really hard? Was there lots of slip, wheel hop, etc...?
Maybe some hard launching going on?
on my mother dude I have never launched that car since it was turbo.... might be i didnt get the oil seal seated right but I dont knoe
If you really like it, keep it. WHat else will you buy? Will it perform as well as this things does/did? How much money are you going to spend putting something together that will be as fast and fun as your Wagon? You don't have to drop the engine to change the clutch. It's a little more work than a usual FWD clutch change, but certainly doable. Did you make sure and set the gear lash correctly on your transfer case gears? There are shims that go between the side gear cover and the transfer case, as well as the transfered gear beaing holder/cover (the cover where the flange sticks out that the driveshaft bolts to) and the case housing. If the gear lash is too loose, this will lead to early failure of the gears. Especially with the power you're putting out.
One last question: when you said you were making 280bhp, did you mean 280 whp? Was your horsepower measured on a chassis dyno? Do you have a dyno plot that you could scan and post up?
Not a fun job.
whoever had my wagon before me shattered the gears just like you, they just pulled the driveshaft side of the gears and put a metal freezer plug into the transfer case... the car drove just fine
Sorry to see what happen to Wagon. I plan on installing a turbo on my Wagon but I am just front wheel drive so I should be OK. Post some pics of your Wagon.
http://photobucket.com/
www.sunrisejdmmotors.com
ive got one i keep for spare parts if your needing anything?
