Cutting fuel to one injector
I don't know why I didn't think of this before... One of my cylinders isn't firing, so a little fuel is probably leaking past the piston rings and getting into the oil, and obviously 1/4 of the gas isn't being used at all. So, my question is: How do you cut the flow of fuel to just one injector?
Hm... I just might. I guess I just didn't know exactly what would happen if I simply unplugged it.
Why no compression?
If your plug is oily and the cylinder's full of oil, you MAY have a hole in that piston-caused by a dropped/chipped valve maybe. Get up with evol911, didn't he offer to help? What's the chances of somebody else on Whidbey on here, too, and willing to hook you up?
