Sonem EF hydro conversion kit install
DOESNT WORK!
but...... i called the guys up and ive gotta send them my pedal assembly and bracket i bought from them and they are gunna make it work for the wagon pedal assembly. they said nothing about different EF's but when i was talking to jeremy he did say that some have a slight difference but mine was WAY off. super nice guys gunna make it work for free thank god cuz im already about $300 into parts beetween the new pedal assemply slave cylinder ect ect..... im kinda pissed ive only driven the wagon about 30 miles since i got it from shenrie before i got tired of the hasport hydro conversion kit which is garbage no one ever buy it!
I looked at several different EF pedal assemblies before buying the kit and I realized the wagon clutch pedal portion is very different from all the others. The clutch pedal pivot point on a wagon's pedal assembly sits about an inch and a half further back(closer to the firewall) than all other EF's. The Sonem bracket mounts to this pivot point, there lies the problem. Knowing this I emailed the guys at Sonem and asked about their return policy in case the bracket didn't fit. They said buy and try it. If it doesn't fit they'll take it back as long as it's not scratched or damaged. Cool on their part I thought! Long story short, I bought the kit and sure enough it did not fit. Instead I decided to use the conversion bracket on a pedal assembly I got from an EX sedan I got at the junkyard. The Ex and SI pedal assemblies are more reinforced around the clutch pedal pivot point which is a known weak point and known to crack. I then used 1/8 thick steel plates to further reinforce the EX pedal assembly before mounting the bracket.
Seemed like a good solution to me. We'll see how it turns out. Just to let you know, you may also have to trim the conversion bracket to get it to fit properly under the steering column reinforcement.
You may also want to change the position of the washers before you weld them to the "hook"
portion at the top of the clutch pedal to ensure a nice straight stroke on the master cylinder.
If not, you may experience a hard clutch pedal or binding due to the awkward angle. Good luck with your project and keep as posted on your progress!
That's why I was interested in your solution. I also tried the Hasport conversion and could never get it to fully engage/disengage the clutch. Then I tried the Innovative Mounts kit w/remote mounted master cylinder but the pedal was extremely hard and eventually ended up cracking my pedal assembly. Keep in mind I am running an ACT heavy duty pressure plate w/6 puck rigid disc. A friend of mine also tried the Innovative conversion kit w/remote master cylinder and had good results. He was using a Tilton single disc clutch on a track only Crx and the pedal felt just a little harder than stock. I will attempt the Sonem kit install in the near future and will hopefully have better luck.
soooooooo i braced the bracket realy good if it breaks ill shit a brick. i then braced the pedal itself. if anyone has ever seen a pedal assembly u can see the clutch pedal has 2 adjustments that let u adjust how much the pedal can travel up and down. i backed the one off so the pedal is fully up when my foot isnt on the pedal then i completely cut off the other adjuster that is suposed to stop the pedal from getting pushed to the floor. then i adjusted the clutch cable so it has just a tiny bit of play so i know its 100% disengaged when my foot is off the pedel. i get 100% disengagement and 100% engagement and adsolutely no flexing in the pedal of the pedal assembly. i will msot likely still snap and stretch cables but oh well ill just be sure to keep a spare in the trunk space next to my spare coil, ignitor, and main relay (something all honda guys should have)
(edit: to post pictures you have to "host" them online (like photobucket.com). then in a reply you add image tags with your pic address between (like this:
I'm a bit concerned about the braided line going through the firewall. You might want to squeeze a rubber grommet into that hole.
Your solution looks good.
8)
about...
fix'n it...
ahh...
nevermind...
