Replacing front strut tops. Where to buy?
Need either a suplier near me (cincinnati) or on the web with a cheap price.
I ordered my coilovers and I'm replacing the strut tops with new pieces.
Thanks
Dan
  • Just stock replacements or aftermarket extended ones? You could just get a set of good stock replacements at a junkyard from any other EF civic. As for extended ones, Ground Control sells a nice set although a little pricey. Ebay also has replicas for much cheaper although I'm not sure about the quality of the hardware used. Several guys on here have also made there own extended top hats using tubing and a welder. Hope this helps.
