Help fitting wind fairing to roof bars...
I thought I knew how it fitted on, I'm sure I'm right, but the bolt that goes through the clip is too wide to fit through the metal bracket...
Am I missing something?
thule new :
http://www.thuleracks.com/product_spare ... 54&sku=871
thule old:
http://www.thuleracks.com/product_spare ... 4&sku=555r
yakima:
http://www.rackoutfitters.com/car-racks ... 91p302.htm
this is the part that you have:
http://www.rackoutfitters.com/car-racks ... 91p150.htm
it may not even be made to mount the fairing bracket. seems like you have incompatible parts. my suggestion would be to make them compatible by drilling out the bracket a bit at the exact location where the bolt is going to go through it. or see if you can change the bolt size if it comes out.
mine look almost identical to this...
i've widened the slots on the brackets already, going to fit it later on
thanks for the help
marc
its cool i dont need pictures, just odd how the brackets that came with my fairing dont fit the bolts through.
cheers
