What kind of love did you give your wagon today
18911131444
  • Threw on a set of fat fives with low pro's (55's)...installed a new door and fender (last week), ordered some LED's to convert some of the interior and exterior bulbs :)
  • Well its not today, but I just got her on the road after being down forever!
    My friends and I have installed new:
    Clutch and pressure plate
    resurfaced the flywheel (ok napa did this lol)
    OEM Clutch pilot bearing
    OEM Throwout bearing
    rear diff mounts bushings and caps
    Honda MTF fluid
    tie rods ends
    ball joints lower
    new grease and boots for the upper
    new alignment
    rear main seal
    cam seal
    Axle seals
    Walmart mod custom cupholder console (lolz)
    shift boot and collar
    OEM underseat tray
    and scored some OEM steelie centercaps for my bottlecaps!
    Brand new all season Kumhos
    Made a harness for the ghetto ran vtec wires
    Correct dipstick out fo a 94 ex
    Painted the rusty b/c pillars
    It feels so good to have her on the road again! All I was supposed to do was the clutch then started replaceing a bunch of stuff. Then went to the junkyard and scored the underseat tray and steelie centercaps off an intact 88rt 4wd.
  • HRDOWTHRDOWT Band Wagon
    installed oil catch can and painted wagon and install d2 coil overs the other day looks much better now! :D
  • Re-balanced all of my wheels. What a difference! :D
    bought a new pedal assembly to replace my fugged up broken set-up, orderd up a sonem hydro conversion kit ill try to do a step by step this weekend on it cant wait!
    A write up on that would be great I need to do that on the crx when it goes K! Today i just cleaned out the wagon thats all, hopefully tomorrow I'll be installing camber kit(poor tires) lol!
  • Switched to winter tires on the RT4WD. Much better than my old ass Falken Azenis.
  • I took it up to 90 mph to pass this slug that was mucking my drive to work! Boy you should have seen his face when this yellow some what rusty Honda Stationwagon with a collector plate passed him like he was standing still! I LOVE My Wagovan!
    Tim
  • puffed somewhat
    aero into
    the tyres...
    i like tyres...
    they float...
    :mrgreen:
    I sent my hood into the bodyshop to get repainted. It looks really bad in person.
    I also bought a block heater and installed new wipers today.
    Well today I put on some new corer lights, rear door panels and sunvisors! Its coming along slowly! Tomorrow I should finally be puting on camber kit and some rear mudflappers! woohoo
    I got new tires on my wagon cause both of my rear tires were seperating and cause nasty vibration. I also finally got the motor broken in, so I did the last oil change and switch to Castrol Syntec 5w30 Synthetic Oil. Just have to do a final valve lash adjustment now that the springs and stuff have fully seated and what not. I'm loving the high compression motor.
  • Dave-ODave-O Wagonist
    I pieced together the turbo setup today. :mrgreen:
    -AirResearch M10/T25 from a Nissan CA18ET
    -Mazda MX-6 FMIC [also got a CA18DET SMIC]
    -HF manifold with adapter plate
    -All new gaskets
    -OBD1 non-VTEC dizzy
    -OBD0-OBD1 patch harness
    -Socketed P75 [already had it, lol]
    And it all cost me $110. :twisted: Just got to get oil lines fabbed up, punch a hole in the pan for the drain, get injectors, and I'm in business.
    Did some work on my seats just bored on my day off but looks way better!
    Got one of my adjustable"camper special" struts built, started Integra swaybar install.
    Hows the sway bar install going?
    mmmm, idk yet. put DA LCAs on backwards to get clearance for the endlinks, now my receiver hitch is in the way.
    Hrm, is that because of the da lca's? Or is that just how the install works on our wagons? I haven't looked into it yet since I haven't had time to even fuck with it.
    Got some HFP 16" fit wheels from Bremerton Honda :)
    $$$$$$$ :( u spent mucho on those huh?? But they look good!
  • My hood is supposed to be done today! I think I'm going to send in the RT4WD rims and have them repainted as well.
    The RT4WD is also down for HG replacement. Also doing block heater and replacing the main relay.
    I ordered a new thermostat for my GF's wagon. It's getting like 15 mpg in town right now, lol. It got new wiperblades last week.
    $350.00, for the set of 4.. from Bremerton Honda... can't beat that!
  • I fited my '90 with 200watt 6.5in speakers in the doors today (sound great). I also put a passenger mirror on in place of my factory delete pannel. Sadly I was unable to find any good mirrors at all (seem to be sooo hard to find), so i ended up with one from my local yunk yard and its missing the glass :(. My driver side taillight was cracked, so I also picked up a new one at the yard.
    Last week the '90 got a new axle back exhaust, a 3in custom intake and new head unit.
    All I really need now is hatch stuts, passenger mirror glass and some headlights. Shes coming along.
    Hell no you can't!! good deal!
    Well last night I decided to steam clean the wagon! Looks wayyyy better!!! It was so nasty!
  • Changed the transmission fluid today, shifts a lot nicer now!
  • one word.....Rotas.
    pix up later haha
  • Washed her for the first time. It's been a little more than a month since the paint job (I gotta get some pictures up) and I'll be showing her off to the local high school's National Honor Society on Friday. Shined with Turtle Wax "Ice", which seems to have done the job. Sure was a lot faster than regular wax.
  • I just replaced my broken tail lights with some stock ones on my '88 and put some fresh JDM tails on the '91. win win right there.
  • on sunday i fixed up my drivers side rear quarter and installed my new HID kit (happy dance)
    fixed my right rear axle just to find out my right front axle is toasted as well....
