Clutch Adjustment Question Please....
I recently was driving my wagon 4wd... it slowly began to get harder to get it into gear... so i adjusted the clutch line.. that worked for a little... then the clutch started to slip.. and then one day it completly stopped going into gear... i did a new clutch and clutch line... its alll back together... but now when i step on the clutch i dont feel like its there. and it wont go into gear... i can push the pedle down.. and it comes back up a little but not all the way...
im so confused.. and getting so frustrated from this... i just wanna be back on the road again.. any advice would be greatly appreciated... ive been searching... but none of the issues are exactly the same...
thanks in advance...
Yeah it's a common one allright. best method is to get one that hasn't yet cracked and then reinforce it.
I am assuming :oops: that it was a failure of my pedal, caused by gradually tightening the cable that left me stranded (and by my previous need to adjust the interlock switch). The pedal is totally twisted and cracked, the cable seems ok (slides easily), however the fact I needed to lift the lever to get crank worries me, as the interlock switch is at the far end of the cable!
I sure hope I'm fixing the right part, and that something internal in the clutch hasn't failed.
Thoughts?
All in all I had to: remove the fuse panel (two nuts and a bunch of electrical connectors), drop the steering column (six nut/bolts), remove both transverse under-dash air ducts (grrrr!), unfasten first the transmission end of the clutch cable then the pedal end (push the cable slightly towards the pedal while depressing pedal a touch) , detch the throttle cable from the top of the gas pedal (easy), pull a cotter pin to detach the master cylinder from the brake pedal, unfasten the pedal cluster (about six nuts) and fish it out.... weld it up and reverse the process! Took me a total of four beer-drinkin hours... next time I'd say I could do it in about an hour or two
Don't forget to adjust your clutch interlock and brakelight engagement switches, and re-adjust your clutch.... and you're done! 8)
PS - My actual clutch was just fine - all my grief was caused solely by the failed pedal... but now the car shifts like a dream and has much better clutch "feel"
it has been broken the whole time ive had the car but hasnt really been a problem until this week.
it started getting really hard to get in gear.
omg so much better! feels like a clutch should now. smooth... and it doesnt sound like im stepping on spongebob every time i shift. haha no squeeks
and thanks scallywag for the overview on what needed to be removed. what a pain in the ass
