Rt4wd help!! no drive to the front at all
I have replaced the drivers side knuckle and everything went back in fine. took it for a test drive and thought the clutch was slipping but its not. turned around on some gravel and noticed the rear wheels were slipping. thought nothing of it. went for another drive and gave it more revs on the gravel and the rear wheels spun. I havent noticed any unusual clunks etc when driving from the front.
Wtf is going on here?
any ideas?
any ideas?
check to make sure the axles are in the trans.
that could be your problem then. what was weird about mine when that happened, was I had no drive at all. I don't think my 4wd is working...?
is it working again then?
