Misfire help!
Number two cylinder doesn't fire at all. Spark is getting to the plug, however I'm not sure if the plug itself is sparking. Any ideas before I go to Autozone tomorrow to pick up new plugs, compression tester, and oxygen sensor?
I'm also a little worried about damage from continuing to drive it like this. How much damage can be done to the engine itself?
Cross the spark plug off your list by swapping from another cylinder. You say it's getting spark to the plug, so the plug itself is the last link.
a,) rebuild engine
b,) replace engine
Squirt a few cc's of engine oil in the plug hole, 3 or 4 pumps from a oil squirt cup. Repeat the compression test on that cylinder. If compression improves noticeably, it's piston/rings. If there's no difference, your problem is valves/head/gasket. This works because the oil will temporarily seal around the piston.
My bet is the problem is in the top end. It's not common to see just one dead hole from lower end problems-it can happen, it just doesn't as often.
Compression increased so about 30. Soo looks like it's time for a rebuild. Or swap?
