Lights on warning beep?
Just got a 88 wagon. Great condition relatively low miles (143000). Was just wondering if there is a stock "hey idiot, you forgot to turn the lights off" warning beep that I need to fix. I do have a "you left the keys in the ignition" beep so I thought a lights on warning should be standard... I was thinking I might figure out the wiring to that (ignition beep) and relay it between the lights and driver door.
I've left the lights on 4 times in the past three weeks. :|
