adrenalinesaint wrote: my understanding it the civic/crx bars fit just fine. hope that helps ;-)
lee123 wrote: Now the qestion is Where can i get some for cheap
hope that helps ;-)
REAR: ok, here is the deal... if you get one of those screw-adjustable bars it will fit fine. if you get a solid one, it will be 2 inches too long. you can either go with the adjustable one, or cut down the and weld the solid one.
Fits just fine in wagovan talk = cut, weld and grind... then, vuala perfect fit!
Ebay. that's where I got mine.
