Door Detent Rod
Hi all
My 88 FWD Wagon's driver's side front door had a loose or broken detent rod. That is; the mount that is inside the body is broken, or loose.
Does anyone know of a way to fix this, without welding the outside of the piece in place?
I guess i could cut out the piece, and then weld it back in after fixing the stuff behind it, however i could not find any other way to get to this piece.
If there is a good post that already covers this that you know about, please LMK
thanks in advance
edit: added a picture from the manual of the part i'm talking about
thanks in advance
Been searching for days and haven't come up with even 1 thread dealing with this issue
Thanks for sharing your experience.
