which fuse box will work with my 91 4wd wagon?
i am looking for a replacement wagon 4wd fuse box (the one under the hood) and was curious which ones will be compatible with mine.
what the real differences are between these items.
i called the dealership and they say the part numbers are different between years but i dont think they know much more then that.
example:
will a 2wd wagon auto fuse box fit into mine?
    i doubt there is much difference between an AT and MT fuse box.. if any at all.
    as long as you stay year specific, the 2WD should work on the 4WD.
  • 949949 Senior Wagonist
    thanks. so i cant even look for a 90 fuse box?
    do you think a crx, hatch, or sedan 1991's will work too or just wagon only?
    any 4th gen Civic should work.
    im curious why they have different part numbers for the ef cause non of them are the similiar to the wagon 4wd.
    im going to check out some local places since they are all the same it should open up more selections.
    it may just be a slight difference in the shape of the box, maybe because the wagons engine bay is shaped a little different then an EF :?
    i did noticed that there is a letter inside the box.
    mine has a letter "F" in it.
    my friends box has a "D". do these mean anything?
