New From WI
Hi I am Cody and I am 17 and from WI, i've been looking to buy a Wagovan for a while now and I have a few questions
Are k swaps possible without insane amounts of custom fab work?
Could i use coil-overs designed for a DA or EF?
What brakes would be the biggest improvement for the least money?
Also what is a high quality axleback for the Wagovan?
And finally, what is a nice front lip and rear spoiler for the wagovan???
Thanks a ton,
Cody
Thanks a ton,
Cody
secondly, almost all of those questions can be found by searching this forum.
as with any EF, a K-swap WILL need quite a lot of fabricating. just a small tip: the front end of the wagon (in terms of mechanical such as engine and suspension) are the same as the sedan or hatchback and CRX.
there are a million and one threads on suspension. go check it out.
same with brake upgrades
..and with exhaust. short answer: there is no direct fitting aftermarket setup out there. you will have to custom fab one.
front lips, well, look at different members rides. quite a few choices out there from 5th gen accord (my favorite) to DA to VW lol
you need to ask for permission & welcome
you could scoop up that roadkill for
the bbq in the back and at that spoiler
you could use as an family-table..
before that roadkill gets cold...
owh, hi and welcome too...
