wagon's brakes keep locking up when car is warm
ok here we go.....replaced master cylinder power booster both front calipers pads rotors both wheel cylinders shoes springs everything except the lines going to each wheel and the prop valve.....everytime the car warms up the front brakes clamp down like the fluid is expanding but if i let the car cool off for a couple hours its fine till it warms back up.....ive bled and bled and bled and im out of ideas so anything will help.....thanks in advance
If Jaker is right it can't hurt to turn it around and try it out.
Under the dash, adjust the brake pedal switch a little more loose.
Soimetimes after replacing master cylinder or booster, the pedal needs to be adjusted.
there is a method for doing this but it is alot easier to loosen the locknut on the brakelight switch and back it off a little.
yup, i've played with that adjustment nut before and it can easily cause what you are describing.
thanks
