help me please??(Will b18a or b1 alt fit in a 92?)
ok just wondering if the b18b's alternator is different from the 92 b18a1's alternator. my 92 alternator is shot and dont wont to shell out the monies for another, if i have one i could just put in and swap out plugs with. so yeah i already know the plugs are different, wondering if i could just swap out plugs with out doing anymore harm, i need my wago runnning. thanks fellas.
  • crv-tecwagoncrv-tecwagon New Wagonist
    ya you can i did for my b20z im not sure were i put my pin out sheet but id check honda_tech.com just repin the plug i havent had a problem
  • jdmeskjdmesk Wagonist
    coo, thanks bud. i knew it would work, and for sure im gonna search for the pinouts.
    ya im rockin a obd2 alternator its the only one we had laying around that would fit.
    hahaha. nice, ok had trouble searching for the pinouts, any help, links?
    is the alternator obd0 obd1 or obd2?
    not sure, the head is stamped 96 n the fuel injector clips dont have the clips.
    what do you mean the clip s dont have any clips? and if you could post a pic that would be sweet
    the injector plugs are just plastic, no metal clips holding them on. just push on the little button and pull.
    are you close to a pic and pull or any salvige yard cause if you are you need to head out the and fill your pockets with those clips or at least zip tie them, but if i know what year or make model that alternator came out of i could find the pinouts
    the head is stamped 96, and it is a jdm b18b from hmotorsonline. the alt. plug is square, with four wires.
    dude im lookin but i dont have much time try google iv work 101 hours this week and im beat
    hahaha, no problemo, thanks alot dude, atleast you tried. get some rest bro.
    ok was gonna repin the new plug with the old wires but the old wires have wider pins, and the new pins are thin. would it be a problem if i just splice the wires together even though the wires are different gauges? and anybody have the alternator wiring diagrams for the wagon and a 96 integra? any help would be very appreciated. :)
    ya thats what i did i also found out the hard way that the pins are diff, but if your going to splice them make sure you solder them and heat shrink em. gauge shouldn't be an issue
    ok thanks. and are the wires running the same pattern as the old pattern? the wires are different color on the harness compared to the 96 harness.
    yes there close in color but do not all match color to color
    http://www.locashracing.com/instructions/OBD0-OBD2x.doc
    ok this should answer all you Q's i finally found it its got dizzy alt and some ecu shit for the v-tec controler, here you go man enjoy :wink:
    thanks dude, that is what i was looking for. couldnt find anything like that. thanks alot. yesssssss..... :D
    no prob glad i could help bro, im good at tracking this stuff next time hit google type in ecu pinouts hit search the click imagas those will bring you to very good info sights mostly on honda tech
    yea i tried that, but that didnt go to well for me. but thanks dude. i really appreciate it. :wink:
