I don't know if the 92-95 Civic Walbro kit will fit the Wagovan tank. I know for sure that the 88-91 Civic kit is NOT a direct drop in for the Wagovan tank. The pick up sock is not at the correct angle, both horizontally and vertically. I made it work, but I have concerns about how well it's going to perform.
doesnt walbro produce fuel pumps for 88-91 civics? err obd0? idk if it matters but my friend has an obd0 b16 with a walbro 255. would those work on a single cause its obd0?
you can find it under the Electronics forum here:
viewtopic.php?f=10&t=6113
Model XFP-341 Xenocron fuel pump
http://www.xenocron.com/xenocron-255-lt ... p-148.html
