What kind of love did you give your wagon today
1679111244
  • with new windshield molding. Looks great
    yeah great thanks for sharing...not! :)
    i'll have to bugger with whipers air filter sparks...i think thats about it...
    for now...sigh
    :mrgreen:
  • noahrexionnoahrexion Wagonist
    Cool shot! I love seeing Wagons enlisted in work. I felt the stock brakes were a touch "small" for towing too; I ended up getting a fairly good deal on some Integra stuff and used that as my upgrade. So far so good. I routinely haul junk with mine too.
  • I routinely haul junk with mine too
    what happened to the donkeys?!
    A cheap, less extensive brake upgrade is to simply upgrade the pads. A good street performance/autocross pad like Hawk HPS would work well. In fact I just put a set on the front of my Miata. :)
    Wagons at work. Awesome thread. I'll be sure to add to it in the future. I'm going to be putting it to work this week...
  • Got my 22" in my trunk! Not for my RT4WD, but it's for my Magnum R/T...
  • Aarron_MAarron_M Band Wagon
    Just bought some cupholders that mount to the vents. One annoyance down. :lol:
    I loved on a lot of wagons today :D
    Welded pedal assembly for BabyJ
    delivered it in Revmaynard's
    Changed Intake temp. sensor in mine
    Oil change, distributor o-ring, washed engine, patched tire on Pebbles' wagon
    Changed throttle body, set timing, Seafoamed Junior's Wagovan
    Drove mine to dinner
    Love got everywhere! :oops:
    Installed projector headlights to replace the bullet hole ridden OEM ones. Bought an EF bumper, but haven't figured out how to remove and replace the trim on top of the EE bumper.
  • RckyMtnEE4RckyMtnEE4 Band Wagon
    lessee, today i mounted/balanced one new tire. I had 3 almost new tires and one stupid old bald bastard.
    Yesterday I had it tinted, 30% all around. Looks sweet.
    A week ago drained/filled the auto trans, the rear diff fluid, spark plugs, air filter, and flushed the P/S fluid. And spent far too much time and brake cleaner spraying off old caked on oil on the block.
    Next week, new timing belt, tensioner, water pump/thermostat, front crank seal, coolant drain and fill.
    mmm, maintenance...
    Starter's going out on me. Bought a replacement. *IT* was defective! Replaced the replacement, haven't had time to install it yet (probably tomorrow). In the meantime I've borrowed my gf's starter from her CRX Si - her tranny's still out of the car so she wasn't using it... :lol:
    Found a DA lip at the junkyard and a mint set of headlights. woot!!!
    sprayed up my t-bar and bonnet latch.. :?
    Got the replacement replacement starter on Thursday and it works. Today I reattached my windshield trim that started falling off.
    Oh, and I reassembled the gf's CRX. That's what I spent most of my day on, actually. It left the garage - not under its own power, but only because the battery lost its charge during the months of storage/repair. Keep in mind that when I brought it into the garage, I was getting dripped on by melting snow and ice. :lol:
  • progressprogress Wagonist
    Removed my front bumper today so I could get the hood open and free the socket wrench I stupidly placed on the passenger side wheel well after I had swapped batteries. Also adjusted the spring on the hood so it would close and open smoothly as closing the hood with the socket wrench caused it to misalign and it screwed up the alignment.
    Found out I need a new rad after noticing many of the fins on the bottom portion were missing. Any suggestions?
    I lowered my wagon with Skunk2 Pro S Coilovers and Skunk2 rear lca's (the bronze ones). The ride is much better since the rear right strut was gone and making thumpy noises. I'm loving the ride, just not sure I like the front mudflaps rubbing when I hit any little bump. Might raise it up a little. We'll see.
    get a new radiator lol
    mine is the same
  • ScallyWagScallyWag Wagonist
    I took mine to see the "TV on the Radio" concert at the Malkin Bowl in Stanley park... Brought the whole outdoor living room / kitchen set up with us, had a bbq, played some bocce, grooved to some tunes... It was pretty choice. Then I drove the hell out of the car on the way home - she likes rough love
    Took mine on a 25 mile off road expedition alongside Pike's Peak this evening.
    dude that third pic is AWESOME. hope you dont mind, but i saved it to my files
    Not at all. :D
  • Looks GREAT! Photo like a PROFESSIONAL Ad. what kinda camera do U have?
  • KroeteKroete Wagonist
    He has got a Nikon D70 I think ;) So it's a professional cam :P
  • yeah thats a good cam and a good eye too i might say
    wagon.............................4ever..................
    I just got "pablo" back from the bodyshop! lookin purdy in YR87M :mrgreen: pics up tonight..
    Yeah, it's a D70. I've taken some college level photography...and that's the extent of my experience. I just shoot alot. The more you take, the better chance of getting a good shot.
    YUSS!
    About time someone did YR87M!!!!
    Haydz wrote:
    YUSS!
    I spent the evening wiring up the rear fogs (thks to Dizzle :) ) Here's a crappy pic :)
    wow that is CLEAN!!!! looks amazing!
  • Got the spindle and front bearing replaced (much nicer now). Popped off the passenger front door car and fixed the window action with epoxy and white lithium grease. Pictures to follow soon.
