ef hatch seats
i was wondering would the ef hatch seats fit into the wagon
    of course, with modifications :mrgreen: you'd have to make a hacth/wagon hybrid seat rail of sorts. but it also depends on the year.
    88-89 had different pans then 90-91.
  • kamanari1kamanari1 New Wagonist
    mine is an 88 and my ef is an 89 i just realllllly hope i can make these work
  • Basically a direct swap over than. Seriously a piece of cake.
    i wonder what about the back seats though
    no back seats are completely different. for one thing wagon seats are 40/60 split, hatchback is 50/50
    i wonder how jdm car boy did it? even if they are 50/50 split i wonder if they are the same width just need to modify. i really want those seats in the wagon because i paid 450 for just the rear and i havent even used them the car broke right when they came in and just have been sitting around
    the mounting brackets for the seats is the problem you'll run into.
    JDMcarboy must have modified these mounting points.
    it is NOT a direct bolt in.
    is there anywhere to get actual jdm or edm seats mine are torn up
    anything is possible is you have money and know where to look :mrgreen: there really is no difference though, other then cloth pattern. EDM headrests are different.
    it would be much easier to find some wagon seats in a junkyard locally (or even not locally). not to mention way cheaper.
    i already have the full sir interior i mind as well make it work if possible
