Second swap on my CRAMMER!!!! (wagon) >>> HELP GUYS
My simple car that would be a donor car :lol:
Sunday pix 6/11/06 (4 hours) started with this:
that's for now, i better sell part first like the JDM SIR headlights and my 2000 GSR hydro tranny, etc. from my civic that i don't need
  • marc-111marc-111 Wagonist
    Bye bye D16y7 in a couple of months that's if i got enough money to buy the parts for the swap :cry:
    www.civicwagon.com
    i'm in the market right now for a B16 cable tranny with LSD to put in my B18c1 GSR, my question is that what clutch do i need to put in there? Like from what car and year model? thanks!
    ANy help? Im about to pick up a J1 JDM B16 tranny? Got it real cheap, so from what car year or model will i use as a clutch for my B18c1 GSR?
    I'm pretty sure you'll need to use the clutch and flywheel from the car that the transmission is out of. Let someone else confirm that though because i'm not exactly up with the play on B-series.
  • HankishHankish Band Wagon
    YEP!
    You will need to use the one from a 92-93 Integra LS cable trans. or 92-93 Teg GSR. but if you tell them you have a JDM cable B16, most will know the corect clutch to use.
    Make sure you use the correct starter with the selected fly wheel. (JDM B16 flywheel will need the JDM starter, the US will need the US starter. the teeth are different)
    Hankish wrote:
    YEP!
    i found out that i could used my ITR flywheel and GSR starter for the cable trans as for the clutch i'm using a 90-93 clutch for it
    now all i need are my parts to arrive :lol:
  • Shaun KShaun K Wagonist
    www.civicwagon.com
    Holy $&(^@#(@....good thing there's free health care in Canada. I wouldn't go anywhere near that car when you've got it jacked up like that.
    Free health here too. ;)
    OSH would be on your ass if they saw that here.
    :lol: i got jack stands on top of blocks on the sides and put it up a wood at a time
    You can get a cherry picker for less than $200 USD :D
    yeah but im broke :( coz i spend all my money for my car
    Like I said...good thing there's 'free' health care up there :D
    :lol:
    btw i pmd you bout some wiring stuff
    could you post a link that you used for your dpfi to obd1 conversion and all the wiring stuff you did to make that engine run?
    all i have now is my obd0 - obd1 ecu harness and the engine harness from my coupe
    marc-111 wrote:
    :lol:
    There isn't much to post...I used a HASport OBD0 to OBD1 harness, subharness, and ecu adapter. I used an OBD1 LS intake manifold, injectors, and fuel rail. The throttle body is from the OBD2 B20, and the MAP sensor is the original firewall-mounted unit from the wagon.
    When it comes to wiring, I'm a lazy and well-connected bastard.
    so you didnt do some splicing and connecting wires to your stock harness? hasport did all of it?
    Here's what i did today! 7/15/2006
    My car can FLY!!!!
    BYE d16y7 :lol:
    Now this is my wagons NEW HEART!!!!!
    Hope i can Finish my swap tom 7/16/2006
    BTW I HATE WIRING but i better try to make it run!!!!! :x
    That motor and trans look great and its going to look even better in your wagon. Keep that valve cover Yellow. It's going to look good with the blue. Good luck. Keep us posted.
    thanks! will install the engine today 7/16/06 only problem is the wiring my dizzy that sucks :x but i'll figure it out
    hopefully i could run on honda day on e-town :D
    BTW NJCIVICWAGON1 im using GSR axles :wink: i tried to put in the axles and it fits perfectly, i'll just hope it would really fit when the engine and everything is on already
    Good Luck. We plan to be there Aug 12 Honda Day. Hope to see you there.
    here she is!!!!
    Did the wiring myself but i suck! i can't make my car start up so i ended up bringing it to my friends shop then he rewired it and it started! will post pix on the members threads for her newest look :twisted:
    Wow. It looks great. Keep us posted.
    only prob now is the cable bracket on the tranny :( the one where you could adjust the cable
    NJCIVICWAGON1: if you have an extra one for a bseries could i pick it up? today? :)
    Damn I wish I had one. Sorry.
    ok thanks! i think i better drop by some junkyards now i really need to drive my car tom :(
