Second swap on my CRAMMER!!!! (wagon) >>> HELP GUYS
My simple car that would be a donor car
Sunday pix 6/11/06 (4 hours) started with this:
that's for now, i better sell part first like the JDM SIR headlights and my 2000 GSR hydro tranny, etc. from my civic that i don't need
YEP!
You will need to use the one from a 92-93 Integra LS cable trans. or 92-93 Teg GSR. but if you tell them you have a JDM cable B16, most will know the corect clutch to use.
Make sure you use the correct starter with the selected fly wheel. (JDM B16 flywheel will need the JDM starter, the US will need the US starter. the teeth are different)
i found out that i could used my ITR flywheel and GSR starter for the cable trans as for the clutch i'm using a 90-93 clutch for it
now all i need are my parts to arrive
Holy $&(^@#(@....good thing there's free health care in Canada. I wouldn't go anywhere near that car when you've got it jacked up like that.
OSH would be on your ass if they saw that here.
You can get a cherry picker for less than $200 USD
Like I said...good thing there's 'free' health care up there
btw i pmd you bout some wiring stuff
could you post a link that you used for your dpfi to obd1 conversion and all the wiring stuff you did to make that engine run?
all i have now is my obd0 - obd1 ecu harness and the engine harness from my coupe
There isn't much to post...I used a HASport OBD0 to OBD1 harness, subharness, and ecu adapter. I used an OBD1 LS intake manifold, injectors, and fuel rail. The throttle body is from the OBD2 B20, and the MAP sensor is the original firewall-mounted unit from the wagon.
When it comes to wiring, I'm a lazy and well-connected bastard.
My car can FLY!!!!
BYE d16y7
Now this is my wagons NEW HEART!!!!!
Hope i can Finish my swap tom 7/16/2006
BTW I HATE WIRING but i better try to make it run!!!!! :x
hopefully i could run on honda day on e-town
BTW NJCIVICWAGON1 im using GSR axles
Did the wiring myself but i suck! i can't make my car start up so i ended up bringing it to my friends shop then he rewired it and it started! will post pix on the members threads for her newest look :twisted:
NJCIVICWAGON1: if you have an extra one for a bseries could i pick it up? today?
http://www.hondacivicwagon.com/board/vi ... .php?t=910
