flywheel on my AWD
I'm going to start putting my wagon back together and I wanted to get your input on if I should use my stock flywheel of a Jun light weight one
Im going to run about 20 psi on this setup
let me know what you think
Let me know what works for on your setup since I plan to re-install my junkyard turbo setup soon. I'll be using a small turbo that is at its 8-9psi peak around 2500-3000 rpm.
