switches or buttons are avail for the 91 wagons
hey guys i am looking for pics of all the types of switches that would fit into our blank spots.
i am doing a project that needs a button or a switch to just turn on and off. i dont want to put an ugly aftermarket one in there. so i dont know what was available to start searching.
(i have the brown inerior, if that matters)
thanks.
thanks.
i dont think this will work because i need a switch that will stay in either on or off positions.
This is the one I am using for the fogs I am going to install. Just pop out the filler panel drill a hole big enough for the switch then bolt it on. The cover is optional, and can be painted.
88-89 dimmer switch fits in the lower holes as well.. but again, prolly not on-off.
honestly, i dont really know any such switches, USDM defroster isnt a true on-off switch, however the EDM (JDM too?) switch IS, meaning when you depress it it stays depressed unlike the USDM one.
same with rear fog switch. 88-89 will fit in the lower holes as well.
you sure about the cruise switch? i have one here from and it stays depressed when pushed in (on). then pops back out when pressed again (off)
I thought of that afterwards.. I'm thinking of a newer honda with a momentary cruise..
oh ok, i see what your saying.
well, i would like to keep it simple. then i would be more interested in a switch that can be as an on / off built in rather then go an extra step.
just dont forget the #amps running through it...
OEM?
but who cares???
