List of Honda Engines
I am compiling a list of engines suitable for use in Civic Wagons/Shuttles. I will also be trying to find out which engine is capable of using the RT4WD int shaft for swap purposes. I will not be including motors that have low power outputs.
Note: All units are metric. This is not a complete list, only selected engines believed to be ideal.
D-Series & ZC
Code: D15B
Market: JDM
Year/s: 1991-1995
Diagnostics: OBD1
Capacity: 1488CC
Power: 96.9Kw @ 6800RPM
Torque: 14.1 Kg/m @ 5200RPM
Compression: 9.3:1
Induction/Valvetrain: N/A SOHC VTEC
Int Shaft Landing: No
Int Shaft Holes Tapped: No
Code: D16A6
Market: USDM
Year/s: 1988
Diagnostics: OBD0
Capacity: 1590CC
Power: 78.3Kw @ 5600RPM
Torque: 13.9 Kg/m @ 4800RPM
Compression: 9.1:1
Int Shaft Landing: Yes
Int Shaft Holes Tapped: Yes
Code: D16A6
Market: USDM
Year/s: 1989-1991
Diagnostics: OBD0
Capacity: 1590CC
Power: 80.5Kw @ 5600RPM
Compression: 9.1:1
Code: D16A8
Market: EDM, UKDM
Year/s: 1988-1997
Disgnostics: OBD0
Capacity: 1590CC
Power: 93.2Kw @ 6800RPM
Torque: 14.9 Kg/m @ 5900RPM
Compression: 9.5:1
Induction/Valvetrain: N/A DOHC
Code: D16A9
Market: EDM, UKDM
Year/s: 1988-1997
Disgnostics: OBD0
Capacity: 1590CC
Compression: 9.5:1
Code: D16Y6
Market: NZDM
Year/s: 1996-2000
Disgnostics: ?
Capacity: 1590CC
Power: 94.7Kw @ ? RPM
Torque: 15.4 Kg/m @ ? RPM
Compression: 9.6:1
Int Shaft Landing: ?
Int Shaft Holes Tapped: ?
Code: D16Y8
Market: UKDM, USDM
Year/s: 1996-2000
Disgnostics: ?
Capacity: 1590CC
Compression: 9.6:1
Code: D16Z6
Market: USDM, EDM
Year/s: 1992-1995
Disgnostics: OBD1
Capacity: 1590CC
Power: 93.2Kw @ 6600RPM
Torque: 14.7 Kg/m @ 5200RPM
Compression: 9.2:1
Code: D17A2
Market: USDM, EDM, JDM
Year/s: 2001-2005
Diagnostics: ?
Capacity: 1668CC
Power: 94.7Kw @ 6300RPM
Torque: 15.8 Kg/m @ 4800RPM
Compression: 9.9:1
Code: ZC
Market: JDM
Year/s: 1988-1995 (OBD0 88-91, OBD1 91-95)
Capacity: 1590CC
Torque: 14.7 Kg/m @ 5700RPM
Compression: 9.5:1
B-Series
Code: B16A
Market: JDM
Year/s: 1988-1991
Diagnostics: OBD0
Capacity: 1595CC
Power: 118Kw @ 7600RPM
Torque: 15.4 Kg/m @ 7000RPM
Compression: 10.2:1
Induction/Valvetrain: N/A DOHC VTEC
Code: B16A
Market: JDM
Year/s: 1991-2000
Diagnostics: OBD1 & ?
Capacity: 1595CC
Power: 122Kw @ 7800RPM
Torque: 16 Kg/m @ 7300RPM
Compression: 10.4:1
Code: B16A1
Market: UKDM, EDM
Year/s: 1988-1991 (OBD0)
Capacity: 1595CC
Power: 110Kw @ 7600RPM
Compression: 10.2:1
Code: B16A2
Market: USDM, EDM
Year/s: 1992-2000
Capacity: 1595CC
Compression: 10.2:1
Code: B16A3
Market: USDM
Year/s: 1994-1995
Diagnostics: OBD1
Capacity: 1595CC
Torque: 16.3 Kg/m @ 7500RPM
Compression: 10.2:1
Code: B16B
Market: JDM
Year/s: 1997-2000
Diagnostics: ?
Capacity: 1595CC
Power: 134Kw @ 8200RPM
Torque: 15.8 Kg/m @ 7500RPM
Compression: 11:1
Code: B17A1
Market: USDM
Year/s: 1992-2000
Capacity: 1678CC
Power: 130Kw @ 7600RPM
Torque: 16.2 Kg/m @ 7000RPM
Compression: 9.7:1
Code: B18A1
Market: USDM
Year/s: 1990-1991
Diagnostics: OBD0
Capacity: 1834CC
Power: 97Kw @ 6000RPM
Torque: 17.4 Kg/m @ 5000RPM
Compression: 9.2:1
Code: B18A1
Market: USDM
Year/s: 1992-1993
Diagnostics: ?
Capacity: 1834CC
Power: 100Kw @ 6300RPM
Torque: 16.7 Kg/m @ 5000RPM
Compression: 9.2:1
Code: B18B1
Market: USDM
Year/s: 1994-2001
Diagnostics: ?
Capacity: 1834CC
Power: 106Kw @ 6300RPM
Torque: 17.5 Kg/m @ 5200RPM
Compression: 9.2:1
Code: B18C
Market: JDM
Year/s: 1993-2001
Diagnostics: ?
Capacity: 1797CC
Power: 132Kw @ ? RPM
Torque:
Compression:
Code: B18C
Market: JDM
Year/s: 1995-2001
Diagnostics: ?
Capacity: 1797CC
Power: 148Kw @ 8500RPM
Torque: 18.9 Kg/m @ 7200RPM
Compression: 11.0:1
Code: B18C1
Market: USDM
Year/s: 1994-2001
Diagnostics: ?
Capacity: 1797CC
Power: 127Kw @ 7600RPM
Torque: 17.6 Kg/m @ 6200RPM
Compression: 10:1
Code: B18C2
Market: AUDM, NZDM
Year/s: 1993-1999
Diagnostics: ?
Capacity: 1797CC
Power: 125Kw @ 7600RPM
Torque: 17.8 Kg/m @ 6200RPM
Compression: 10:1
Code: B18C4
Market: UKDM, EDM
Year/s: 1996-2000
Diagnostics: ?
Capacity: 1797CC
Power: 124Kw @ 7600RPM
Torque: 16.1 Kg/m @ 6200RPM
Compression: 10:1
Code: B18C5
Market: USDM
Year/s: 1997-2001
Diagnostics: ?
Capacity: 1797CC
Power: 145Kw @ 8200RPM
Torque: 18.3 Kg/m @ 7500RPM
Compression: 10.6:1
Code: B18C6
Market: UKDM, EDM
Year/s: 1998-2001
Diagnostics: ?
Capacity: 1797CC
Power: 140Kw @ 7900RPM
Torque: 18.1 Kg/m @ 7300RPM
Compression: 11.1:1
Code: B20B
Market: JDM, USDM
Year/s: 1996-1998
Diagnostics: ?
Capacity: 1973CC
Power: 94Kw @ 5400RPM
Torque: 18.1 Kg/m @ 4300RPM
Compression: 9.2:1
Code: B20B
Market: JDM
Year/s: 1999-2000
Diagnostics: ?
Capacity: 1973CC
Power: 109Kw @ 5400RPM
Torque: 18.3 Kg/m @ 4300RPM
Compression: 9.6:1
Code: B20Z
Market: USDM
Year/s: 1999-2000
Diagnostics: ?
Capacity: 1973CC
Compression: 9.6:1
Getting there, still in progress...
D-Series & ZC
Code: D15B
Market: JDM
Year/s: 1991-1995
Diagnostics: OBD1
Capacity: 1488CC
Compression: 9.3:1
Code: D16A6
Market: USDM
Year/s: 1988
Diagnostics: OBD0
Capacity: 1590CC
Compression: 9.1:1
Code: D16A6
Market: USDM
Year/s: 1989-1991
Diagnostics: OBD0
Capacity: 1590CC
Compression: 9.1:1
Code: D16A8
Market: EDM, UKDM
Year/s: 1988-1997
Disgnostics: OBD0
Capacity: 1590CC
Compression: 9.5:1
Code: D16A9
Market: EDM, UKDM
Year/s: 1988-1997
Disgnostics: OBD0
Capacity: 1590CC
Compression: 9.5:1
Code: D16Y6
Market: NZDM
Year/s: 1996-2000
Disgnostics: ?
Capacity: 1590CC
Compression: 9.6:1
Code: D16Y8
Market: UKDM, USDM
Year/s: 1996-2000
Disgnostics: ?
Capacity: 1590CC
Compression: 9.6:1
Code: D16Z6
Market: USDM, EDM
Year/s: 1992-1995
Disgnostics: OBD1
Capacity: 1590CC
Compression: 9.2:1
Code: D17A2
Year/s: 2001-2005
Diagnostics: ?
Capacity: 1668CC
Compression: 9.9:1
Code: ZC
Market: JDM
Capacity: 1590CC
Compression: 9.5:1
B-Series
Code: B16A
Market: JDM
Year/s: 1988-1991
Diagnostics: OBD0
Capacity: 1595CC
Compression: 10.2:1
Code: B16A
Market: JDM
Year/s: 1991-2000
Capacity: 1595CC
Compression: 10.4:1
Code: B16A1
Market: UKDM, EDM
Capacity: 1595CC
Compression: 10.2:1
Code: B16A2
Market: USDM, EDM
Year/s: 1992-2000
Capacity: 1595CC
Compression: 10.2:1
Code: B16A3
Market: USDM
Year/s: 1994-1995
Diagnostics: OBD1
Capacity: 1595CC
Compression: 10.2:1
Code: B16B
Market: JDM
Year/s: 1997-2000
Diagnostics: ?
Capacity: 1595CC
Compression: 11:1
Code: B17A1
Market: USDM
Year/s: 1992-2000
Capacity: 1678CC
Compression: 9.7:1
Code: B18A1
Market: USDM
Year/s: 1990-1991
Diagnostics: OBD0
Capacity: 1834CC
Compression: 9.2:1
Code: B18A1
Market: USDM
Year/s: 1992-1993
Diagnostics: ?
Capacity: 1834CC
Compression: 9.2:1
Code: B18B1
Market: USDM
Year/s: 1994-2001
Diagnostics: ?
Capacity: 1834CC
Compression: 9.2:1
Code: B18C
Market: JDM
Year/s: 1993-2001
Diagnostics: ?
Capacity: 1797CC
Torque:
Compression:
Code: B18C
Market: JDM
Year/s: 1995-2001
Diagnostics: ?
Capacity: 1797CC
Compression: 11.0:1
Code: B18C1
Market: USDM
Year/s: 1994-2001
Diagnostics: ?
Capacity: 1797CC
Compression: 10:1
Code: B18C2
Market: AUDM, NZDM
Year/s: 1993-1999
Diagnostics: ?
Capacity: 1797CC
Compression: 10:1
Code: B18C4
Market: UKDM, EDM
Year/s: 1996-2000
Diagnostics: ?
Capacity: 1797CC
Compression: 10:1
Code: B18C5
Market: USDM
Year/s: 1997-2001
Diagnostics: ?
Capacity: 1797CC
Compression: 10.6:1
Code: B18C6
Market: UKDM, EDM
Year/s: 1998-2001
Diagnostics: ?
Capacity: 1797CC
Compression: 11.1:1
Code: B20B
Market: JDM, USDM
Year/s: 1996-1998
Diagnostics: ?
Capacity: 1973CC
Compression: 9.2:1
Code: B20B
Market: JDM
Year/s: 1999-2000
Diagnostics: ?
Capacity: 1973CC
Compression: 9.6:1
Code: B20Z
Market: USDM
Year/s: 1999-2000
Diagnostics: ?
Capacity: 1973CC
Compression: 9.6:1
Fixed.
