*SOLVED* studdering/surging at cruising speeds
the wagon is studdering/surging while trying to maintain a constant speed. it's small but annoying. any ideas? the only ECU code i am getting is CEL 20. Electric Load Detector. so far i'm thinking TPS sensor or Dizzy.
thanks gang.
*solved*
turned out to be a broken TPS wire. not sure why it threw an o2 code as well. codes cleared, car runs like a freaking champ.
thanks gang.
*solved*
Have you tried this yet? Sounds like a good place to start if you have checked all terminals and earths.
after doing some searching on honda-tech it seems that the answer is quite probably my o2 sensor. it was replaced last year with a 'universal' sensor. they require to splice the wires and it is frequent for that to cause problems. i guess they also make another one that uses a factory plug. also frequent for it to NOT throw a CEL. i'll get around to it when i get really annoyed.
my guess is now the ECU has changed it's fuel maps to compensate for a completely toasted o2. before the sensor was sending faulty information. now the sensor is completely shot, possible for the ecu to go to a 'default' map?
i'll see if my MPG are terrible or not. if not, i'm leaving it alone.
and take the sledge...
if we let you hit the pinata
we'll starve to death...
