A/C removal
OK so i want to retain my heater but remove anything that involves A/C.
I've already removed the A/C pump and A/C radiator when i initially did the engine swap, now i want to remove anything under the dash that isn't required, but still keep the heater (its 0-1 degrees celcius here in the morning).
Under my dash i have two units, a big black box and a round white thing. Can i get away with just removing both of these and re-ducting or will i need to do something else?
I had a search around but most of the good resources seem to have disappeared. :?
Cheers in advance,
Hayden.
