Physical RT4wd differences: Auto vs Manual?
So From what I can gather, the main difference between the Auto/Manual version of the 4wd wagons (EE) is the transmission and the shifter? The ECU is obviously different as well as some of the wiring, but to make it work all you should need is the shifter assy and the transmission right?
Thanks,
Parker
Thanks,
Parker
***Edit*** Just went and had a look at HondaPartsDeals, and assuming their listings are correct, the above is also correct.
