just doesnt wanna turn over sometimes... y?
so i'm wondering why, sometimes the engine just won't turn over after i'm done driving it. i've noticed... after i drive it (occasionaly) when i go back to start'er up, it just won't turn over. Kinda seems like the engine would be flooded. I'll wait about 10 minutes really, and it'll start. But it's very hesistant on starting than.
Now usually it takes a few seconds of cranking to get it to start up initially for the first time each day. Should i be just sitting there warming it up for a few minutes? It looses idle and dies if I don't normally.
Also, today... Well i just got it back a few days ago. As the timing belt snapped en route. I've lost cylinder #2. it 'runs' right now on 3 cyl's... I'm waiting for some spare $$ to go hit up the jy and get a crx head, and new headgasket. But what i'm wondering, is should i do the jy run, or could i just replace the valves...? mechanic said there was a bent valve.. i physically haven't seen it, as i can't work on the car in my apartments..
Recommendations?
btw: engine is EW1/2 1.5l carb'd 1986 with over 200k
Recommendations?
so i'm curious. i'm trying to research some info on possible swaps.. now since my fuel system is for carb'd... is it easily done swapping a d15b non-vtec dual carb....?
this is what i'm lookin at
http://www.tigerjapanese.com/index.php? ... &Itemid=26
edit: Find a carb'd ZC or a d16a1 and carb it
that's all anyone has noticed!!!!
just get like a weber carb kit for the d16? that what you mean? i have no idea how to make it so it's carb'd...
I know that d16a1 motors are the only direct swap into your year wagon because they have the unusual motor mount(and you can't just swap the mount because it bolts differently to the block/head) but you would have to swap the wiring harness over from the your year Civic/CRX Si to be able to run fuel injection. I think JDM wise the dohc Integ motor was the "Si" motor for the early Civic/CRX's.
