FWD REAR SUBFRAME... CAN I SWAP IT?
Whats up guys.... Now that I slammed my wagon. My rear subframe is hitting the street hard. Im sparking all over the road. I dont want to raise the car. Does anyone here tried to swap the rear subframe with a 88-91 EF hatch or CRX. They dont seem to drop as low as the wagons rear subframe. Let me know. Thanks in advance.
i searched through Hondapartsdeals.com to see the part but i couldnt find it
the Wagon one has it under "rear lower arm" but the hatchback and sedan dont, which may mean they are in fact be part of the lower pan.
whatevahsss
No airbags for me. I want to keep it slammed with custom shocks/coilovers. I'll do bags on a VIP project in the future thou.
My wagon is currently as slammed as possible. If a custom subframe is the answer then I shouldnt be doing this. Lets see what I come up with. Thanks for the input fellas...
Call me crazy but I might just want to go a tad lower. :twisted:
Q,
how much room do you have above the tire? Dropping it more may require some fabbing to tuck it up in there.
Another Q,
How is that on your axles? They must be blowing like a hooker in vegas.
correct. its really hard to explain. but i dont see any way you could use a ASR subframe brace with a wagon rear subframe. the only way would be to take a crx/civic subframe and copy it to the wagon frame rails. but then idk if the lcas are in the exact same spots in the frame rail.
overall i just dont think it would be worth it.
the second pic is a wagon subframe. notice it isnt built the same but it also bolts from the bottom up. the design just isnt the same to use a ASR brace.
also for what he is trying to use it for it wouldnt help anyways. im guessing he is hitting the bottom of the subframe and the ASR covers the backside of a normal subframe.
hope this helps. i cant find how to really explain it. :oops:
I don't think it would be very difficult at all for someone with a little welding and fabrication know how to mod that for more ground clearance. If it were for a 4WD that would be a totally different story, but 2WD, there plenty of room to raise it up. You could probably even make it so the ASR subframe brace/swaybar mount would bolt up.
The only way you can do it is with a custom rear sub frame. I can probably make one. I'm just lazy.
Green = ef rear lower strut bar. Red = subframe pan hangs low and curves outwards so that a straight strut bar will not mount onto its intended location.
Ok, if you just want a support bar on a wagon subframe you could do what I wanted to do a couple of years ago. I get a ef rear lower strut bar and mount it on the front side of the subframe instead of the back side. You will have to cut out the welded nuts on the lca mounts and buy longer lca bolts. I don't know if you get the picture but the idea really won't do much for looks, because it will be on the front of the subframe, but you could have it there for peace of mind.
